Fedora Workstation (36) on Pinebook Pro
(08-31-2022, 04:43 PM)u974615 Wrote:
(08-30-2022, 09:50 PM)pjsf Wrote: did you use dnf to install the rpm or software-center or something else?
so if you do lsmod do you see brcrmfmac loaded? I was actually misrembering , the only firmware I needed to find was BCM4345CS.hcd for the bluetooth support.
I used "$ sudo rpm --install brcm-pinebookpro-0.0-1.noarch.rpm"
I even copied (cp -r option) all the firmware files from the working Manjaro Plasma installed on the eMMC to the Fedora 36 Workstation image.
lsmod doesn't list brcmfmac nor any brcm module.
I was going to remove all the existing firmware files and re-copy the firmware files again.
so what happens if you do modprobe brcmfmac?
(08-31-2022, 07:14 PM)pjsf Wrote: so what happens if you do modprobe brcmfmac?
Actually, it is working now.  I cleared out all the firmware files and copied over the Manjaro Plasma ones.  And upon booting it up Wifi started working.
That's good! How's performance on emmc?
(08-31-2022, 08:07 PM)pjsf Wrote: That's good! How's performance on emmc?
Not too bad.  I haven't used the laptop much.  I feel like the slowness really is in the booting and not the eMMC speed.
Also, I suspect that the 4GB of RAM is probably causing more of the sluggishness that I experience when in GNOME3 shell.
  Debian on Pinebook Pro u974615 8 449 03-22-2024, 03:57 PM
Last Post: u974615
  Fedora 37 installation gswatkins 16 5,535 03-16-2024, 03:09 PM
Last Post: michel_luc
  Pinebook Pro upgrading from the factory image yamsoup 12 1,126 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,921 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,981 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 86,673 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 994 11-23-2023, 07:37 AM
  Fedora 36 -> 37 upgrade kills system tydeman 0 371 10-28-2023, 09:53 AM
Last Post: tydeman
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 4,931 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,326 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
