Mobian on PPP
Where is the settings tool or how to install It? In the latest weekly omg that I installed on the SD, cannot see it
You will have to find an older img file to install.
Once an image with the Settings app is running, then the apt-get dist-upgrade command can not be used until further notice. We have to settle for apt-get upgrade until critical packages are no longer nominated for deletion with no replacement, and packages are no longer held back from upgrade.
Look for org.gnome.Settings.desktop in the /usr/share/applications directory.
Many thanks
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 10 1,727 11 hours ago
Last Post: mburns
  Disable the GDM service in Mobian. mburns 0 462 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 879 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 496 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 702 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 597 10-14-2023, 11:57 AM
Last Post: mburns
  Mobian libnotify custom notifications MadameMalady 5 1,394 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,113 07-27-2023, 04:12 PM
  XFCE mobian running nicely but some oddities grump_fiddle_reinstall 0 799 07-01-2023, 08:18 AM
  [Mobian] : Battery consumption and OS compatibility freelectro 2 1,071 06-02-2023, 06:55 AM
Last Post: Fred Zyphal
