Battery problem with a Pinephone keyboard and Mobian
I have a Pinophone equipped with the Pinephone keyboard (operating system: Mobian).
As indicated in the instructions, to recharge the Pinephone, I plug the usb cable from the charger into the usb input on the keyboard.
Until a recent update, with Mobian, once the battery was charged, the charge indicator showed 200%. It seemed a little strange to me, but considering that with the keyboard battery, the device has two batteries (keyboard battery + Pinephone battery), there is a logic to the matter… and there was no problem. My Pinephone had a battery life of about two days.
But since a recent update, things have changed:
I can still charge the Pinephone by plugging the usb cable into the keyboard input, but it seems that mobian no longer detects the keyboard battery.
After charging for a whole night, the charge indicator in mobian only shows 65% maximum. Also the keyboard battery doesn't seem to charge the Pinephone battery Undecided
Result: the autonomy of my pinephone went down to about ten hours!
Does anyone have a clue to help me?
Thanks Smile
I am using Manajro ARM (Phosh) and I have the same problem.
Quote:uname -r
Linux manjaro-arm 6.0.2-1-MANJARO-ARM #1 SMP PREEMPT Wed Oct 19 06:43:45 UTC 2022 aarch64 GNU/Linux
Previously, it used to show 66% on a full charge,
but after updating to the latest version, it shows 33% on a full charge.
Perhaps the latest version of Mobian (Weekly) will also show 33% on a full charge.
I do not know how to correct the problem.
I wish I had a better solution....
Quote:cat /sys/class/power_supply/ip5xxx-battery/uevent
     1  POWER_SUPPLY_NAME=ip5xxx-battery
     2  POWER_SUPPLY_TYPE=Battery
     3  POWER_SUPPLY_STATUS=Not charging
     4  POWER_SUPPLY_CHARGE_TYPE=N/A
     5  POWER_SUPPLY_CHARGE_BEHAVIOUR=auto
     6  POWER_SUPPLY_HEALTH=Safety timer expire
     7  POWER_SUPPLY_CAPACITY=86
     8  POWER_SUPPLY_CALIBRATE=187
     9  POWER_SUPPLY_VOLTAGE_MAX_DESIGN=4200000
    10  POWER_SUPPLY_VOLTAGE_NOW=4016064
    11  POWER_SUPPLY_VOLTAGE_OCV=4166452
    12  POWER_SUPPLY_CURRENT_NOW=-7460
    13  POWER_SUPPLY_CONSTANT_CHARGE_CURRENT=2300000
    14  POWER_SUPPLY_CONSTANT_CHARGE_CURRENT_MAX=3100000
    15  POWER_SUPPLY_CONSTANT_CHARGE_VOLTAGE=4228000
    16  POWER_SUPPLY_CONSTANT_CHARGE_VOLTAGE_MAX=4242000
Quote:cat /sys/class/power_supply/axp20x-battery/uevent
     1  POWER_SUPPLY_NAME=axp20x-battery
     3  POWER_SUPPLY_PRESENT=1
     4  POWER_SUPPLY_ONLINE=1
     5  POWER_SUPPLY_STATUS=Charging
     6  POWER_SUPPLY_CHARGE_BEHAVIOUR=auto
     7  POWER_SUPPLY_VOLTAGE_NOW=4249000
     8  POWER_SUPPLY_CURRENT_NOW=270000
     9  POWER_SUPPLY_CONSTANT_CHARGE_CURRENT=1200000
    10  POWER_SUPPLY_CONSTANT_CHARGE_CURRENT_MAX=1200000
    11  POWER_SUPPLY_HEALTH=Good
    12  POWER_SUPPLY_VOLTAGE_OCV=4194300
    13  POWER_SUPPLY_VOLTAGE_MAX_DESIGN=4200000
    14  POWER_SUPPLY_VOLTAGE_MIN_DESIGN=3000000
    15  POWER_SUPPLY_CAPACITY=99
The image below shows the PinePhone (+ PP Keyboard) almost fully charged.
(10-28-2022, 02:24 PM)presire Wrote: Previously, it used to show 66% on a full charge,
For me, on Mobian and PostmarketOS it's started displaying 25% on a full charge.
My current theory is it's due to changes in how the UPower daemon calculates the display percentage. Have a look at my thread about it:
https://forum.pine64.org/showthread.php?tid=17740
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 41,741 10-27-2025, 10:19 AM
  cryptocurrency on mobian/pinephone biketool 35 57,764 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 26,764 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 1 2,130 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 272,508 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 1,905 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,438 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,855 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 2,852 04-29-2025, 02:10 PM
Last Post: mdk
  On-Screen Keyboard Arrow Keys biketool 10 5,346 03-27-2025, 03:03 PM
