Pinetime stuck at infinitime logo
Hi all,
my brand new pinetime is stuck at the "infinitime logo" after 2-3 days.
I've used gadgetbrige to flash the 1.9.0 firmware as soon as the watch arrived. Everything was fine for about 2 days. After that the "inititime" logo appeared and i got stuck there. I've discharged the watch, read some help request so i went in the blue recovery and then in the red one and got it flashed again. Seemed fine for about a day and then "infinitime logo" again.
Tried to flash it again with 1.9.0 or anything but nothing worked. Rebooted phone, tried gadgetbrige, nrf connect, different boot (green, blue and red) but i can't associate the watch with gadgetbrige anymore (no entry there so no flash) and with nrf connect i get a "starting DFU, disconnecting" with nothing done apparently (uploading the firmware usually require about a minute).
Any idea on how i can recover from here?
Thanks!
small update, tried yesterday. If i leave the watch in charge or discharging, everything is fine. If i start any kind of dfu update via bt the watch reboots. it doesn't make any difference if i do that on green, blue or red startup. anyone has an idea on how to get the watch back?
Same here !
Recovered!!!!!
Following the thread here
https://forum.pine64.org/showthread.php?tid=17121
I've downloaded a previous version of nrf connect from here
https://github.com/NordicSemiconductor/A...4.22.3.apk
Then I've flashed successfully
pinetime-mcuboot-recovery-loader-dfu-0.14.1.zip
(I don't know if it's relevant, i don't think so)
After all I've flashed infinitime 1.8.0 and seems to work.
Finger crossed....
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 2,231 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 2,928 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 9,918 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 4,371 07-30-2025, 11:44 PM
Last Post: karthick
  ? Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 2 1,316 07-29-2025, 04:49 AM
Last Post: oscar-gardiazabal
  PineTime charging issues - connecting pins black gsoundsgood 2 2,495 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 3,911 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 7,902 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 4,737 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 1,738 01-31-2024, 11:57 AM
Last Post: tynstar
