Calls 4G not working
I noticed a problem with making calls when mobile service is 4G. When I tried to make a phone call it ended quickly. When I switched to 3G it worked. On my android phone when I was making calls it automatically switched to 3G every time (only during a call). Is is a carrier thing? Maybe It would be nice to add this automatic switching feature like in android devices.
(07-01-2022, 07:20 AM)oliwierzgorniak Wrote: Hi,
do you have 4g only mode? if so, switching does not work.
in my knowledge switching should work normally on eg25-g modem chip. maybe you should re-initialize volte settings just in case. https://wiki.pine64.org/wiki/PinePhone#VoLTE
for volte, lot of things could go wrong. device may not have support, carrier does not have support, device may have blacklists for not supporting certain carriers (referring to that android device), or carrier may blacklist devices (particularly in u.s.).
I got the same problem even if I am not in 4G Only mode. Outgoing calls are not working but incoming calls are working because the network switches to 3G during the call.
I am using Mobian with Phosh on the PinePhone and found a workaround by changing the network mode from "2G, 3G, 4G (Preferred)" to "2G, 3G (Preferred)" (this is not a good solution for the long term since 3G will be shut down in the future).
Trying to use VoLTE by following information on https://wiki.pine64.org/index.php/PinePhone#VoLTE did not work (but anyway if it is not working, it should switch to 3G like for incoming calls).
Maybe updating the firmware will fix the issue like someone mentioned here (I am using Free Mobile in France with the default modem firmware EG25GGBR07A08M2G_01.001.01.001):
https://wiki.pine64.org/wiki/PinePhone_C...ort#Sweden
The issue is also mentioned here:
https://www.reddit.com/r/pinephone/comme...und_calls/
Update: The issue happened with version 01.002.01.002 and 01.003.01.003 (or versions below) but not with version 30.004.30.004 and 30.006.30.006 (with or without the custom firmware 0.8.0 https://github.com/the-modem-distro/pinephone_modem_sdk).
VoLTE support still needs confirmation on https://forum.pine64.org/showthread.php?...#pid125496.
With the old default firmware, there was also an issue when receiving SMS while connected to 4G, I received it several times indefinitely. The issue does not seem to happen anymore with a new firmware.
  New camera app gnome-snapshot working on trixie? vusra 4 2,758 04-11-2025, 02:53 AM
Last Post: vusra
  Mobile internet via cellular network mostly not working Anna 18 20,185 01-19-2024, 02:59 AM
Last Post: anonymous
Exclamation The internal speaker stops working anonymous 6 5,373 01-17-2024, 05:53 PM
  APN settings not working with new operator SIM card user641 1 2,510 03-01-2023, 04:43 PM
  Possible Solution for Microphone Not Working Ferriah 0 2,022 02-13-2023, 01:09 PM
Last Post: Ferriah
  No audio on calls after updating today Zebulon Walton 10 11,507 12-12-2022, 09:55 PM
Last Post: BaronAlbatross
  Squeekboard stopped working Zebulon Walton 2 3,251 11-24-2022, 08:41 PM
  suspend inhibit no longer working jsch 3 4,140 10-23-2022, 09:20 AM
Last Post: LibrePhoneUser
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 10,334 09-05-2022, 12:10 AM
  How to get Pinetime working with Pinephone arkadione 12 13,610 08-28-2022, 12:30 PM
Last Post: Fish
