apt-get update "The following signatures were invalid..."
Try
sudo apt-get dist-upgrade
(07-23-2022, 01:25 PM)ljones Wrote: Can't update here as well. I can't install curl (I get 404  Not found) so I tried using wget above but it makes no difference.
404 Not Found errors on a new install of Mobian are caused by trying to download from an automatically-selected Debian mirror that is incomplete. If you manually choose a Debian mirror (one that is actively maintained) and enter it in /etc/apt/sources.list, you won’t have 404 Not Found errors any more.
This checks out -  you can find a suitable mirror here: https://www.debian.org/mirror/list
The only thing I would add is that you do need to comment out the current listed archive since there seems to be some issue currently with that server.
This worked for me.  You should be able to select whatever mirror is close.
#deb http://deb.debian.org/debian bookworm main
deb http://debian.csail.mit.edu/debian bookworm main
I just read somewhere on mobian's site that apt-get gets you less than just apt, and that apt upgrade is a bit conservative, it won't drop unused stuff, won't install what already wasn't there, that apt dist-upgrade will. Also, it said that the apt-get dist-upgrade combination is most likely to fail a lot.
  trixie update poll questions suggestions j_s 5 467 10-22-2025, 07:14 AM
Last Post: anonymous
  how to update mobian over tor vusra 14 15,352 12-04-2024, 07:01 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 3,350 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 3,581 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 11,693 02-26-2023, 01:01 PM
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 10,265 11-28-2022, 03:30 PM
  Wifi issue since last update and held back updates goku499 11 11,888 09-21-2022, 02:39 PM
Last Post: Katsujinken
  [SOLVED] Lost Internet connectivity after recent update drh 3 3,996 09-11-2022, 09:24 PM
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 10,385 09-05-2022, 12:10 AM
  Loving latest Mobian Update drh 11 10,956 08-22-2022, 12:19 PM
