PinePhone Pro not detected by my PC
#21
You need to hold volume down button immediately after powering on and seeing the red light + first vibrate. That'll boot to the sd card.
I'd also like to see the output of
lsblk
and your dd command being issued.
[/quote]
To illustrate my edit of my last point I waited for a minute to press enter to show you the status of the installation. It won't install if the inter button is not consistently being pressed.
What did I do wrong here?
https://imgur.com/Qne62oo
Edit: is it that i should type mmcblk1? not mmblk1?
I did try it with mmcblk1 in lieu of mmblk1 and there was no difference still wont install unless i hold the enter key
[/quote]
  Having difficulty installing PostmarketOS on Pinephone Convergence Beta edition spazz 11 377 10-11-2024, 10:46 PM
Last Post: spazz
  PinePhone doesn't boot anymore lapin 3 373 09-13-2024, 10:09 AM
Last Post: lapin
  New PinePhone Pro fails... P. Siera 5 919 08-01-2024, 04:56 AM
Last Post: P. Siera
  A way to view or log the splash screen on Pinephone Pro running ArchLinux (Danctnix) PHLEMON 4 763 07-30-2024, 11:03 PM
Last Post: PHLEMON
  PinePhone Pro silver lining, it’s fast, real damn fast ashoka232 2 1,599 07-30-2024, 05:58 AM
Last Post: DrYak
  Is my PinePhone Pro dead? jlioret 2 1,953 07-28-2024, 04:12 PM
Last Post: dchang0
  Pinephone Pro does not start with RE button pressed c0ssan 11 7,486 07-28-2024, 03:21 PM
Last Post: dchang0
  Will a Pinephone Pro (Explorer) work with TING wpeckham 8 4,199 07-28-2024, 03:04 PM
Last Post: dchang0
  Pinephone Pro: Determined To Make It (Drive-able) USeeks 3 779 07-20-2024, 10:11 AM
Last Post: mikehenson
  Show me your "portable" PinePhone Pro setup! Danct12 5 4,263 07-20-2024, 12:04 AM
Last Post: Emeliaee3
