Chrony interrupts calls.
Completed calls had been being briefly interrupted every few seconds and often terminated unexpectedly.  I turned off Chrony and this behavior stopped.  Turned it back on and the behavior resumed.  Evidently the phone can't deal with Chrony sending udp packets in the background during a call.  Sound is still so noisy and laggy as to be unusable, calling is unreliable, and I still have no data, but this is progress.
Also with Chrony active the ModemManager log cycles like this
<info>  [modem0] 3GPP registration state changed (home -> idle)
<info>  [modem0] 3GPP registration state changed (idle -> registering)
<info>  [modem0] 3GPP registration state changed (registering -> home)
Stopping Chrony seems to have put a stop to that.
[Edit]
I can now complete calls (still not usable) with WiFi turned off. "ping 8.8.8.8" (or any other address) gets 5 to 10 returns and then stops. When I check the modem
state it has come unregistered. Trying to use data breaks something.
  Calls 4G not working oliwierzgorniak 2 3,843 08-06-2024, 02:20 PM
Last Post: baptx
  No audio on calls after updating today Zebulon Walton 10 11,541 12-12-2022, 09:55 PM
Last Post: BaronAlbatross
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 5,050 02-18-2022, 08:54 AM
Last Post: battlegarden
  Calls : two rings and call cut and restore. Gribouille 0 1,657 01-14-2022, 07:40 AM
Last Post: Gribouille
Question Best Way of Receiving Calls Without SIM (VOIP) lovepine88 16 20,502 10-07-2021, 12:38 AM
Last Post: AndyM
  *urgent help*calls and gnome-conatcs gone after update user641 24 29,207 09-20-2021, 12:19 PM
Last Post: calinb
  How does calls work in debian? temp0rary 4 6,752 05-31-2021, 10:44 AM
Last Post: temp0rary
  SIP for gnome calls cmicallef 1 3,366 04-26-2021, 06:30 AM
Last Post: vongillus
  Difficulty making calls Zebulon Walton 10 12,277 04-21-2021, 12:12 PM
  Phonebook does not link with calls canaac 3 5,049 02-08-2021, 04:03 PM
Last Post: canaac
