Writing to SD card possible with all applications?
Android from about vers. 5.0 on does not allow to write to the external SD card for all applications. Is it possible to write to external SD card for instance with OpenOffice with the PinePhone (a reason to buy a PinePhone)?
Of course you can. You can write and run an entire operating system from the SD card if you want.
Thumbs Up
Happy to know, thanks, Merc Smile .
The PinePhone is as far as I know the most affordable Linux Phone which has full control over the external SD card (read and write) Heart . Other affordable Linux Phones almost only allow reading from the external SD card. Pine64 can advertise with that. The last Android phones which could do this job was as far as I know for instance the Galaxy S5 with Android KitKat 4.4. This was the last Android device I was happy with. Now I will update to the revolutionary PinePhone, which brings this beloved feature back.
You have full access on any phone you can install PmOS on too - check their device list to see what works and what doesn't on different devices. It's a software issue not a hardware issue.
Thanks for the info for PmOS to solve this painful problem, that is the second option on the market to solve this problem I know now.
This is really a great option which started with the QTEK 9000:
https://de.wikipedia.org/wiki/Datei:Pock...-08-26.jpg
and ended up with the Samsung Galaxy S5 Android KitKat 4.4.:
https://www.gsmarena.com/samsung_galaxy_...-11050.php
and has now a revival with the PinePhone which can write to the external SD card, together with the PinePhone keyboard, which makes it look like a QTEK 9000:
https://pine64.com/product/pinephone-pin...oard-case/
For those who want their data on a (encrypted) SD card and nowhere else.
  Does Ubuntu modify a Pinephone SD boot card? Peter Gamma 0 917 10-05-2023, 09:18 AM
Last Post: Peter Gamma
  External SD card not listed by Pcmanfm? Peter Gamma 1 1,601 08-22-2023, 12:22 PM
  Device memory full on multi-boot SD card Peter Gamma 4 2,794 08-27-2022, 10:03 AM
Last Post: Eugo
  wiping u-boot off sd card shulamy 6 3,009 08-17-2022, 03:38 AM
Last Post: shulamy
  Quick and easy bootloader option for JumpDrive on external SD card? Peter Gamma 5 2,775 05-02-2022, 06:57 AM
  Launching OS in the SD card from p-boot in MMC chuso 0 1,240 10-01-2021, 09:02 AM
Last Post: chuso
  Easiest way to use Android applications on Pinephone esud 4 8,625 06-21-2021, 04:52 AM
Last Post: vanja
  Unable to mount the INTERNAL SD Card dgdimick 3 4,184 03-30-2021, 07:45 PM
Last Post: dgdimick
  Silly Kali Linux script for Mobian SD card sergio.pantalone 0 3,386 03-08-2021, 10:08 PM
Last Post: sergio.pantalone
  SD card mounted to access music files unable to play dcinoz 3 3,681 02-24-2021, 11:48 PM
Last Post: dcinoz
