Armbian and LibreELEC and AltLinux for Quartz64
Libreelec kernel 6.13
Armbian kernel edge 6.14
Altlinux kernel 6.14
(02-26-2025, 11:30 PM)balbes150 Wrote: Libreelec kernel 6.13
So far this is the best build of Amrbian I can find. I tried building myself, but I run into a couple of issues. My builds seem unstable. I get micro stuttering and am not sure where to look to debug. I can only seem to build with 6.11 kernel.
This image was solid. I had a bit of trouble on first boot where it wasn't starting the first time boot setup, but after that I really havn't had a major issue.
I am a novice at this but have built amrbian for a number of boards using their build environment on git. Building for the original pine64 has worked great for me.
I wanted to try this out with KDE or xfce. I guess I could just install the other desktop environment and change it.
Have you, or has anyone, tried getting the MIPI DSI lcd working on any of these builds?
I do not know, I do not have such equipment for the test.
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 6 14,182 09-01-2025, 10:26 AM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 1,510 07-30-2025, 07:19 AM
Last Post: pugzarecute
  USB on Quartz64 Zero litbulb 0 1,086 11-13-2024, 08:16 AM
Last Post: litbulb
  DietPi OS for Quartz64 MichaIng 47 41,186 08-08-2024, 07:42 AM
Last Post: ifreislich
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 69,855 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 3,652 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 3,112 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 3,708 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 8,256 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 2,514 07-21-2022, 01:08 PM
Last Post: Randomuser
