Pinecil 24V mod
Hello.
Here is my solution to make Pinecil work with 24V power supply. Simple over voltage protection with 1k resistor and 20v zener diode.
So did you cut the connection from the barrel plug to the USB-C-chip and connected the USB-C-chip via 1k resistor and Zener diode to the barrel plug?
And the USB-C-connector is still directly connected to the chip?
Or what changes you did on the wiring?
Regards!
  Request for Pinecil V2 Gerber Files – Unable to Import Due to Customs Restrictions Qwerty 0 1,020 02-07-2025, 10:51 AM
Last Post: Qwerty
  Pinecil (V2) "HES"-stand? InfiniteBSOD 0 792 01-02-2025, 04:59 PM
Last Post: InfiniteBSOD
  Does Pinecil v1 support hakko T12 style tip? xsetiadi 1 3,143 02-02-2024, 03:30 PM
Last Post: SooperPoopyPants
Question Pinecil tip for installing threaded inserts? smcleod 4 5,736 09-11-2023, 06:36 PM
Last Post: kifujin
  Pinecil V2 -boards only DrYak 1 3,178 08-30-2022, 03:59 AM
Last Post: DrYak
  Broken pinecil (?) sh4ttered 2 4,268 02-16-2022, 01:50 AM
Last Post: sh4ttered
  Idea: Pinecil wood burning tip (pyrography)? ijsbeer 4 8,852 10-29-2021, 03:58 AM
Last Post: Fred Zyphal
