Keyboard case not charging (or not working) and a possible FIX for both
I had the same issue, keyboard working but no charge unless I pressed the shell and phone.
Since I thought I saw a slight bulge I got suspicious of the plastic "guide" pin in the shell. It would make sense since it seems the pogos closest to it has the problems.
So I took a knife and remove a few millimeters of the plastic guide pin and now my keyboard shell seems to work as it should.
I have no idea what longterm ill effects this might have but for now it works for me.
(04-25-2022, 04:04 AM)Humid Stylus Wrote: Since I thought I saw a slight bulge I got suspicious of the plastic "guide" pin in the shell. It would make sense since it seems the pogos closest to it has the problems.
Thanks for this suggestion.
I started having the same problem with the keyboard not connecting to the PinePhone today. I came to the same conclusion after having no success with contact cleaner and reinstalling the PinePhone a couple of times. If I pressed on the back of the case directly above the pogo pins it would connect, but only while I kept pressing. I was looking at the keyboard case where the pogo pins connect and also noticed the rectangular locating pin. After reading your comment I used a sharp craft knife and shaved a fraction of a mm off the pin. It now connects easily with both keyboard and power.
If it's like the ordinary PinePhone back cover that's a retaining clip not a guide pin, and you sometimes have to press the back cover there for it to engage. The only reason to have a clip in the middle like that is to improve contact on the pogo pins, but if the clip isn't engaged it will make contact worse.
  Pinephone (Pro) Keyboard Case for sale manubert 3 13,073 08-26-2025, 06:06 AM
Last Post: zetabeta
  keyboard case charging but not typing new2pinephone 19 18,488 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 3,514 10-07-2024, 11:08 PM
  Troubleshooting Pinedio LoRa Add-on Case nickp 2 2,575 09-29-2024, 09:17 PM
Last Post: lavabrilliant
  Getting started with fingerprint scanner case lolgzs 1 3,027 09-08-2024, 04:21 AM
Last Post: mfashby
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 14,100 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 0 2,221 07-19-2024, 08:02 AM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 3,402 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 1,863 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 3,065 06-29-2024, 09:36 PM
