Gadgetbridge vs RF Connect
For an Android phone with pinetime running Infinitime, which app is better or preferred and why?
"nRF Connect" suits good only for Firmware update, and for developers.
for regular users on Android the "Gadgetbridge" is the only one of kind - it's the Companion app, and support a lot of feature (e.g. Firmware update, date/time sync, notifications sync, some steps sync).
for list of other Companion apps, see the "Companion apps" section here https://github.com/InfiniTimeOrg/InfiniT...anion-apps
Away
Gadgetbridge appears to be a good choice for pairing with an Android device. Worked for me for firmware updating, but I'm yet to try notification pushes.
Can someone tell me if Gadgetbridge can be run on the Pinephone via Anbox, or some other Android emulator?
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
  setting data sync interval to Gadgetbridge dhdurgee 0 310 10-09-2025, 01:13 PM
Last Post: dhdurgee
  Unable to switch from Wasp-OS back to Inifinitime using GadgetBridge Bruce Kissinger 0 1,383 10-02-2024, 07:31 PM
Last Post: Bruce Kissinger
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 7,902 06-25-2024, 12:21 AM
Last Post: Amen
  Issues Connecting with GadgetBridge XOmniverse 1 2,364 06-04-2024, 02:45 PM
Last Post: bof
  Connect to Google Fit on Android? Ccssid 0 1,786 12-24-2023, 09:06 AM
Last Post: Ccssid
  Watchmate doesn't connect to PT anymore jojuma 1 2,523 02-07-2023, 02:43 AM
Last Post: azymohliad
  can anyone suggest their working Linux bluetooth USB dongles to connect to Pinetime? jahway603 4 5,268 07-27-2022, 07:38 PM
Last Post: jahway603
  Flashing with RF Connect ronaldheld 12 13,456 04-28-2022, 04:27 AM
Last Post: ITCactus
  PineTime re-connect to PInephone kmsgli 8 9,479 01-01-2022, 08:05 PM
Last Post: kmsgli
  BT WONT CONNECT mindwave 8 10,301 11-19-2021, 03:18 AM
Last Post: danielt
