Debian image configured for USB-C OTG?
I have a RockPro64 booting 5.10.0-7-arm64 #1 SMP Debian 5.10.40-1 (2021-05-28) aarch64 GNU/Linux from microSD.
USB-flash drive does mount in the USB-C port, but I need to do ethernet-over-USB, so I need the USB-C port in peripheral mode.
But the kernel is configured with:
  • CONFIG_USB_OTG not set
  • CONFIG_OF_OVERLAY not set
  • device-tree dr_mode="host"
I've been to https://packages.debian.org/bullseye/linux-image-arm64 and  https://d-i.debian.org/daily-images/arm6...rd-images/ but don't want to randomly try other images without knowing how the kernel and device-tree are configured.
Suggestions on how to find a correct Debian image?
Suggestions for other Linux flavors that do have the required configuration?
TIA.
(12-19-2021, 10:08 AM)djonathan Wrote: ...
Happy to report what my config has if you spoon feed the commands that may reveal what you need - I am
$ lsb_release -a
LSB Version:    1.4
Distributor ID:    Arch
Description:    Arch Linux
Release:    rolling
Codename:    n/a
chris@RPro64:~$ uname -a
Linux RPro64 5.15.7-2-MANJARO-ARM #1 SMP PREEMPT Fri Dec 10 00:02:34 CET 2021 aarch64 GNU/Linux
which is basically the Pinebook Pro image with  RockPro64 DTB.
$ lsb_release -a
LSB Version:    1.4
Release:    rolling
Codename:    n/a
Hello
This has nothing to do with the thread.  But I read on another thread you were trying to change your pass code using the terminal.
Do you mind giving me the code to change my pass code on Mobian?
Thank you in advance, Susy 1075
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,459 08-16-2023, 01:34 AM
Last Post: varac
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,163 04-23-2023, 11:02 PM
Last Post: Thisone
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 2,820 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 4,549 02-19-2022, 06:44 AM
Last Post: sigmaris
Bug Unreliable display in Armbian and Debian ksattic 3 5,461 11-17-2021, 05:42 AM
Last Post: PakoSt
  Debian Bullseye & RockPro64: No tty consoles? Pete Tandy 9 13,046 11-08-2021, 02:33 PM
Last Post: TRS-80
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 3,417 10-29-2021, 11:15 AM
Last Post: TRS-80
  Two Questions About Debian on RockPro64 publiclewdness 0 2,147 09-30-2021, 11:54 AM
Last Post: publiclewdness
Question Booting official Debian on RP64 arteeh 6 9,883 07-06-2021, 10:16 AM
Last Post: TRS-80
Big Grin Feature Complete Debian Desktop Release Mrfixit2001 158 249,663 05-29-2021, 04:05 AM
Last Post: twilite
