Mobile internet via cellular network mostly not working
(02-22-2022, 05:31 AM)Anna Wrote:
(02-22-2022, 03:44 AM)anonymous Wrote: Be careful, it may ruin your battery life.
I haven't measured it yet.
But battery life has always been bad (I don't go out without a 10,000 mAh power bank and a charger) and depends heavily on usage: When the phone is on standby, it works for almost two days and when in use, it lasts not much more than two hours (guesstimate) - so I really would have to do a controlled experiment to gauge the impact.
But at least battery life has not become so much worse that I would have noticed an obvious difference during the ten days since I made the change. The crashing modem had made the phone completely unreliable; now the phone is usable. So it's definitely a good trade from my perspective.
Have you enabled any power saving options?
(02-22-2022, 05:48 AM)anonymous Wrote: Have you enabled any power saving options?
Not conciously, no. Are there any (besides the "Settings" menu)?
Not that I know...
A recent update seems to have brought an additional problem that prevents mobile Internet connections.
This can, however, apparently be fixed fairly easily; two solutions are described in the thread DNS Problems with Mobile Data .
What worked for me was the solution by Zebulon Walton as summarised by arno_nuehm:
sudo apt install resolvconf
sudo nano /etc/resolvconf/resolv.conf.d/head
In that Document add the line
nameserver 9.9.9.9
(or "nameserver 1.1.1.1" or whichever DNS server you like) at the bottom of the text. Then save, close and go:
sudo systemctl restart resolvconf.service
sudo systemctl restart systemd-resolved.service
That's all.
Any sustainable solutions to the other problems are still welcome.
The battery drainage is extreme indeed. According to a little test I did, the Pinephone can remain in standby for only five to six hours with ATTR set to "on" and more than 34 hours with "auto" (see below).
Of course you won't notice the difference as much if you actually use the phone because that will drain the battery in no time with both settings.
Unfortunately, I will have to stick to the "on" setting since otherwise the modem will crash so often that the phone is actually unusable.
Or does anybody have a fix for BOTH problems so that I would not have to choose between short battery life and a permanently defunct modem?
        ATTR{power/control}=
hours  "auto"  "on"
0        100%   100%
1          93      82
2          91      60
3          88      42
4          85      26
5          83      15%
6          80    OFF
11        54%
15        43
23        41
28        19
30        14
31        11
32          8
33          6
34          4%
35        OFF
(02-26-2022, 11:01 AM)Anna Wrote: The battery drainage is extreme indeed. According to a little test I did, the Pinephone can remain in standby for only five to six hours with ATTR set to "on" and more than 34 hours with "auto" (see below).
hours  "auto"  "on"
0        100%   100%
1          93      82
2          91      60
3          88      42
4          85      26
5          83      15%
6          80    OFF
11        54%
15        43
23        41
28        19
30        14
31        11
32          8
33          6
34          4%
35        OFF
Nice work! Thanks for the effort.
(12-04-2021, 08:27 AM)Anna Wrote: For some time now (since Bookworm? Or only a few weeks? I actually don't know) I usually don't have internet access via the mobile network.
Sometimes it works, mostly it does not. A restart usually helps, but of course that's not what you want to do when you need to quickly look something up or when you or wait for a Signal/Telegram message while on the move. The problem occurs with two different providers.
Is there anything I can do?
I noticed tonight that my 4G data is no longer working. The 4G connection seems to be up and there is plenty of data on my plan. Rebooting and updating have not helped.
Prior to this 4G data has been pretty solid with only the occasional reboot to get it up and running again.
Edit ; I will try the resolvconf fix above as the modem is reported to be working but nothing resolves.
(02-26-2022, 11:01 AM)Anna Wrote: Or does anybody have a fix for BOTH problems so that I would not have to choose between short battery life and a permanently defunct modem?
Stay near to a wall outlet? Big Grin
I kid but, power and reliability issues are deep in firmware and kernel stuff, and will take time to sort out. So all we can do in meantime is try and cheer each other up.
Cheers,
TRS-80
Protocols, not Platforms
Question
(02-21-2022, 07:39 AM)Anna Wrote: I finally found out how to make the mobile internet work on my phone, I hope you can make any use of it:
For some reason there are two APNs from my provider (O2 Germany) in Settings/Mobile Network/Access Point Names: There is "pinternet.interkom.de" and there is "internet". When I don't have a data connection, I have to switch to the respective other APN and everything works. I have no idea what it depends on and of course this workaround is not ideal, but it's at least less tedious than restarting the phone and hoping that it will work.
I found that out after I had followed zetabeta's advice to set ATTR{power/control}="on" instead of ATTR{power/control}="auto" in the first line of /usr/lib/udev/rules.d/80-modem-eg25.rules (reboot afterwards or make udev load the new rules). This minimises the notorious modem crashes (in fact I hardly had any crashes since changing it), which is great in itself; I'm not sure whether it contributed to the fact that I have mobile internet.
Anyway: My pinephone is now perfectly usable.
Hello Anna
Happy new year. Does zetabeta's advise still work on Mobian Trixie? It helped me a lot under Mobian Bookworm despite the high energy consumption.
Exclamation The internal speaker stops working anonymous 6 1,082 01-17-2024, 05:53 PM
Last Post: anonymous
  APN settings not working with new operator SIM card user641 1 1,052 03-01-2023, 04:43 PM
  Possible Solution for Microphone Not Working Ferriah 0 964 02-13-2023, 01:09 PM
Last Post: Ferriah
  Not connecting to cellular network car46999 18 7,532 01-30-2023, 12:06 AM
Last Post: car46999
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 1,601 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 1,404 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 2,599 12-01-2022, 09:18 AM
Last Post: traut
  Squeekboard stopped working Zebulon Walton 2 1,207 11-24-2022, 08:41 PM
  need help with downgradin network-manager Ferriah 0 655 11-07-2022, 04:51 PM
Last Post: Ferriah
  DNS Problems with Mobile Data arno_nuehm 29 17,191 10-29-2022, 09:16 AM
Last Post: treebeard
