NVme intall usage?
I installed an SSD in my pinebook pro.  It is there, lsblk shows
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
nvme0n1      259:0    0 931.5G  0 disk
But the disk doesn't show up in Dolphin?  The wiki says you can use it as a data disk.  What am I missing?
(11-07-2021, 02:37 PM)tkudog Wrote: I installed an SSD in my pinebook pro.  It is there, lsblk shows
Found the solution in https://forum.pine64.org/showthread.php?tid=10366
"Just an FYI for folks that have installed a new NVME drive, but don't know what to do with it.
It needs to be partitioned, formatted and mounted for you to use it.  If you're not used to installing drives on computers, this may not be obvious.
Here is a decent tutorial of how to do that:  https://www.digitalocean.com/community/t...s-in-linux"
Then you may have to change owner to access it like you want.
Started with moving /var to nvme this week, messed it up but will make a write-up when it works.
  New Working nVME gilwood 0 204 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,506 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,794 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,310 03-05-2022, 04:53 AM
Last Post: mattpenn
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,845 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,634 12-10-2021, 07:47 PM
Last Post: josmo
  NVMe SSD testing methodology halogen 1 2,612 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,752 07-09-2021, 08:45 PM
Last Post: moonwalkers
  nvme drive disappears after about an hour of uptime codebreaker 25 31,972 02-09-2021, 11:32 PM
Last Post: dsimic
  NVME SPI Update not booting SD Card WZ9V 5 6,370 10-18-2020, 08:36 PM
