Mobian September 01, 2021
Just flashed a September 01 Nightly to an sd card,  running on a Pine Manjaro Convergent phone.
It did the normal disk 'resizing',     But there was no pop-up to help put the basic information into the phone.
  Now there is not a flashlight app on the desktop,  or in the onboard Software Store. ?
I did the "Updates" via   settings > about > update,  that went normally  using the wifi...
I attempted to use the cell/data after putting in my APN info, and turned on mobile data,  both Epiphany and Firefox would not load.
Then turned wifi back on,  Epiphany loaded...  turned wifi off again,  mobile data back on,    this time Epiphany loaded via cell/data.
Calls work both directions,  while the other person can hear me clearly, and they sound clear to me,  but I sound distorted to myself on the ear piece.
The text works, both in and out.  ...
AND  in the Power App,  with wifi off,  data off  just the modem on,
    While running on the battery,     it is showing between 2.0 and 2.2 watts of discharge. !
That is getting the power consumption down,  a bit lower with each release.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(09-01-2021, 04:15 AM)bcnaz Wrote: Just flashed a September 01 Nightly to an sd card,  running on a Pine Manjaro Convergent phone.
For what it's worth, the flashlight should be working from the drop down menu (or notification menu whatever it's called). Also, if you go to Mobile settings (inside of your Settings) and change Network Mode to 3G, 4G (Preferred) it really helps the call audio. I've also found that after setting my APN it took a bit of time before it properly connected but has been working fine for about 2 months or so.
Thanks for the info on the pull down, there is the "Torch"
I was pretty tired, but determined to try the September 01 nightly release.
Seems to be drawing less power on this release.
Using one of my test phones at the moment.
I have it set to see most of the page, but it is hard to make out the tiny print !
On a Manjaro Convergent phone, September 01 nightly Mobian release on an
sd card, Pure Talk for data connection.
If you just want to read the forum, landscape mode works pretty well.
but in landscape mode when you pop up the keyboard you cannot see much of anything... so I end up using portrait mode if I want to write anything
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Mobian repository status henrythemouse 16 8,746 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 2,002 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 131 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,994 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,821 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 633 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,897 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,898 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 631 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,018 06-19-2023, 03:02 PM
Last Post: vusra
