Bleachbit on Mobian
Bleachbit : from the Mobian onboard software store installs both user and root in just one install.
  However only the user part part will open and work.?
 Is there an easy work around,  or just wait for the developers to get it working ?
Sent from my PMOS phone, August 22 Mobian/Bookworm Nightly on sd card, PureTalk cell/Data
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I wonder if Bleachbit can be used safely with Mobians f2fs file system ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Well...
I see Mobian has moved from f2fs to ext4...
I do wonder if they will return to the f2fs later, or what..?
Will Bleachbit as 'root' eventually work on Mobian ? ( as 'user' is only a part of the app. that currently works)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(01-06-2022, 08:58 PM)bcnaz Wrote: Well...
With the mobian installer you can choose between f2fs and ext4..
(08-23-2021, 05:49 AM)bcnaz Wrote: Bleachbit : from the Mobian onboard software store installs both user and root in just one install.
Problem is bigger than bleachbit. Many GUI software do not run with root privileges.   In the past gksudo was available to run GUI software as root. Example https://forum.pine64.org/showthread.php?tid=14469 Who has solution?
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 65 23,087 07-12-2025, 07:46 AM
Last Post: anonymous
  cryptocurrency on mobian/pinephone biketool 33 50,052 06-30-2025, 02:57 PM
  XLibre for Mobian Hiraghm 1 243 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 242,179 06-25-2025, 01:19 PM
  VoIP account on mobian dialer j_s 0 162 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 347 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 713 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 782 04-29-2025, 02:10 PM
Last Post: mdk
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 870 01-15-2025, 08:08 PM
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 754 01-02-2025, 12:47 PM
Last Post: zetabeta
