Bad apple (video) playing on a pinetime
Video
I put bad apple on the pinetime.
You can also watch it on odysee:
https://odysee.com/@TT-392:b/bad-apple-pinetime:8
Source code:
https://github.com/TT-392/pinetime-bad-apple
https://github.com/TT-392/Pinetime-bad-a...-processor
Haha very cool demonstration! Can you share some technical description of how this is working? (I see the source, but I mean some high level description about what you did.)
Depending on the bitrate, I wonder whether whether it could be possible to stream video via BT - that could be a legitimately useful (and uber cool) feature!
Great work Smile
(08-10-2021, 08:47 AM)barray Wrote: Haha very cool demonstration! Can you share some technical description of how this is working? (I see the source, but I mean some high level description about what you did.)
Great work Smile
I might put some more effort into a proper technical description on the github page at some point though not today.
But anyways, I'll give a quick description here:
The main magic happening here, is in the fact that this video is preprocessed beforehand on a powerful desktop pc. This thing first takes out only the pixels that actually change. And then tries to figure out the optimal blocks to write this to the display.
The way you write something to the display is: x1, y1, x2, y2, bitmap. I call these blocks.
Basically, writing a new block takes time, and writing pixels in a bitmap takes less time, so the bigger the blocks the better. So basically, if you have a block of 10x10 of changing pixels, with one non changing pixel in the middle, it is faster to overwrite that pixel, than to write 4 blocks around it. So that is basically what the preprocessor does. These blocks are then put in a file, with coordinates of the blocks (second relative can be encoded in 4 bits), followed by a 1 bit bitmap. This file is then lz4 compressed, and written to the spi flash of the pinetime. The pinetime decompresses, processes the blocks, and writes them to the display.
As for bluetooth streaming, I kinda doubt that would be doable, I haven't looked into bluetooth yet, but if the speed is anything like the time it takes to upload through nrf connect (uploading this video takes about half an hour). I doubt that is gonna happen. But idk, maybe some optimizations are possible.
You mention
`The main magic happening here, is in the fact that this video is preprocessed beforehand on a powerful desktop pc. This thing first takes out only the pixels that actually change. And then tries to figure out the optimal blocks to write this to the display.`
What Video preprocessing application are you using, Adobe After Effect ?
And the speed of the video appears smooth because of the powerful Hardware ? So what is the PC like ? i7 Intel or Alienware's that are used for gaming.
Thanks for the Awesome video
(08-10-2021, 09:49 AM)TT-392 Wrote: I might put some more effort into a proper technical description on the github page at some point though not today.
Please do!
(08-10-2021, 09:49 AM)TT-392 Wrote: The main magic happening here, is in the fact that this video is preprocessed beforehand on a powerful desktop pc. This thing first takes out only the pixels that actually change. And then tries to figure out the optimal blocks to write this to the display.
Haha I figured there was at least some magic Smile
(08-10-2021, 09:49 AM)TT-392 Wrote: The way you write something to the display is: x1, y1, x2, y2, bitmap. I call these blocks.
Is it that both the 'disk' (flash) is limited _and_ the write speed to the display?
Given the nature of the video, it could be worth checking out some vector graphics. The decision of what to send next to the display could possibly even be done real time.
(08-10-2021, 09:49 AM)TT-392 Wrote: This file is then lz4 compressed, and written to the spi flash of the pinetime. The pinetime decompresses, processes the blocks, and writes them to the display.
That sounds awesome Smile Do you get much savings with lz4? I assume the data you are sending is already pretty high entropy?
(08-10-2021, 09:49 AM)TT-392 Wrote: As for bluetooth streaming, I kinda doubt that would be doable, I haven't looked into bluetooth yet, but if the speed is anything like the time it takes to upload through nrf connect (uploading this video takes about half an hour). I doubt that is gonna happen. But idk, maybe some optimizations are possible.
Depends how much data you are sending, but BT should be capable of some reasonable bitrate if you can stream audio over it. You'll definitely want some buffering though (as you do with audio).
The benefit to such a system is that you could potentially then stream all kinds of things from say a computer or mobile - it could lead to very interesting capabilities. For example:
* Remote photo taking on a camera
* Stream map data from phone
* Play a high-end graphics game streamed from your phone to watch (and use the watch as a dumb terminal of sorts) - games that could be cool are fruit ninja or angry birds for example
Anyway, if video could be streamed via BT it could add massive functionality!
(08-13-2021, 08:42 AM)Mpoint Wrote: You mention
The preprocessing is not like you'd do in an application like adobe Adobe After Effect. It is just turned into an image sequence (done with ffmpeg, and some imagemagick) and then ran through what I call the preprocessor, which is just a custom application that I wrote to optimize the format of the video for display performance, and to fit it in the limited space of the watch, it is basically just processing the video into a more practical custom file format, specifically designed for the watch.
The video doesn't get smoother thanks to powerful hardware. I wasn't really clear about this in my comment, but when I mention a powerful pc, I mainly mean powerful compared to the watch, it is optimized on a desktop pc first, which is processor intensive, before it is flashed onto the watch, if this is done on a less powerful pc, the preprocessing is gonna take long, but it isn't gonna change anything about the smoothness of the final video. Also, because it took about 2.5 hours to do the preprocessing on a ryzen 7 1700, it might take really long to process the video on a less powerful machine. (the application does do multithreading, so it is not just singlethreaded performance that counts here)
Both the flash and the display share the same 8 MHz spi bus. This spi speed, and the fact that the only real way to send data to the display is in bitmaps (as in, you can't just tell it to draw a line or square, you have to send each pixel individually), in practice, this means that the fastest way to rewrite the entire screen is 125 ms (8 fps). We aren't really limited in terms of flash speed, because there is enough still frames, and frames where not much happens that enough data can be fetched to keep the buffer full.
I don't really see how this would speed things up or would make things more compact, also, you could probably do the processing real time, but stuff would be a lot less optimized.
It goes from 5046208 bytes to 4099181. Which makes it small enough to fit in the 4 MiB of spi flash
Full color imagery, where small changes in color tint happen all over the display quite often (like remote photo taking on camera) is gonna be really slow on this display, this video is really only possible because big blobs of the same color pixels are moving around the display, though, still images of the camera, or, if a max speed of 8 fps, are probably possible (depending on bluetooth speed and stuff of course). For this same reason, games streamed from your phone are gonna look horrible, if they aren't specifically optimized for this display. Also, bluetooth as a protocol is definitely capable of high bitrates, but idk about this specific implementation of low power bluetooth hardware, I'd have to look into that.
  PineTime at FOSDEM jmlich 5 892 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 279 01-31-2024, 11:57 AM
Last Post: tynstar
  PineTime and Amazfish on Ubuntu Touch jmlich 1 794 10-14-2023, 04:12 PM
  PineTime is dead!! Markdanni123 12 14,062 09-18-2023, 10:17 PM
Last Post: ccchan234
  PineTime Sleep Tracking any_mouse 12 12,595 07-10-2023, 05:41 PM
Last Post: davidair
  PineTime Dead out of box? henkery 1 1,269 03-12-2023, 04:34 PM
Last Post: henkery
  Pinetime almost dead... only shows Infinitime logo. lightweight 8 6,946 02-11-2023, 09:30 AM
Last Post: alexmitroff
  PineTime beginner MV1791 2 2,253 01-09-2023, 11:52 PM
Last Post: Canyonless
  Struggling to detect Pinetime over bluetooth John45595 0 1,192 11-20-2022, 11:06 PM
Last Post: John45595
  PineTime Dev Kit for sale igor.bljahhin 2 3,254 10-19-2022, 05:34 AM
Last Post: peatord
