PINEBOOK Pro USB-C Docking Deck compatibility
Hello people, just saw on twitter the new PINEBOOK Pro USB-C Docking Deck.
I have 2 question though:
  1. Does this USB-C dock work with any USB-C/Thunderbolt 3 port say MSi notebook?
  2. In my consideration the cable is too short. Some notebooks have the USB-C on the back of the computer so you need at least half a meter to put the dock properly on the side, otherwise you have to buy an extension.
https://19216811.cam/ https://1921681001.id/
Right from your link, "The Docking Deck can only function with the PINEBOOK Pro Laptop".
Any other use is at your own means. Buy an extension if you need one. Else buy the dock you want.
:wq
  Could Someone Give Advice on Optimising Pinebook Pro for Software Development? Octaviah 0 1,685 08-23-2024, 12:45 PM
Last Post: Octaviah
  [Pinebook Pro] Where to buy a new TFT and how to replace it? openbsd98324 2 2,398 07-23-2024, 07:14 AM
  Pinebook Pro with RK3588? tantamount 28 19,811 07-13-2023, 04:06 PM
  The power of the Star64 vs Pinebook Pro/RockPro64 Starfall 1 2,647 04-17-2023, 05:00 AM
Last Post: lkoini
  Could an arm based pine 64 smaller than normal to go with the pinebook zanewiller 1 2,581 07-12-2022, 03:33 AM
Last Post: Weatherburn
Lightbulb NUT (Network UPS Tools) compatibility Scary Guy 0 1,690 04-22-2022, 08:12 PM
Last Post: Scary Guy
  Could an arm based pine 64 smaller than expected to go with the pinebook zanewiller 1 2,866 04-16-2022, 07:17 AM
Last Post: jiyong
Star Very Lightly Used PineBook Pro ragnarlothbrok64 4 5,336 01-21-2022, 02:36 PM
Last Post: sascha
  Buy a Pinebook kaizmoto1489 3 5,852 07-14-2021, 10:08 AM
Last Post: poVoq
  Pinebook Pro has become dead, no lights? JohnKarpenter 3 5,318 07-01-2021, 12:57 AM
Last Post: TfromTexas
