Mobian repository status
@biketool Glad you're up and running Smile
(08-10-2021, 09:56 AM)nelstomlinson Wrote: Does Mobian do backports? Or will Mobian Bullseye be not quite frozen? I really want stability and don't want to enable testing if I can avoid it.
As is stands, I believe Mobian relies on some bleeding-edge software from upstream, such as PinePhone-specific firmware. Ergo, there are "third-party" repositories configured to serve those packages.
For ubiquitous userland programs, such as the GNU coreutils, there is no reason why the Mobian developers couldn't use stable. However, this changes when you consider phosh, and other packages developed for the PinePhone and Librem 5.
Mobian could introduce a backports-like system to achieve this, but it isn't available.
I think the Mobian Developers are going to stay on the cutting edge, I believe they are going to jump into 'Bookworm' Debian shortly after the Bullseye release.
"Debian" will continue to support the Mobian mobile branch with security updates.
Check out the Mobian Blog for more details.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Backports would be nice, because that would let me just update a few programs that I actually need to have updated.
Bookworm would be OK for Mobian, except running testing for the whole distro causes a bunch of issues.
Maybe the question I should have asked is: ``What sources lines should I have to keep sort of up to date, without having something important break on every single update?''
Pinephone beta edition, convergence model, Mobian Bookworm with Phosh.
Hi I'm having problems update pinephone pro with phosh. It says mobian.org could not connect. I have also checked mobian.org and it seems down for the last three days. Any help??
(04-09-2024, 09:44 AM)covar Wrote: Hi I'm having problems update pinephone pro with phosh. It says mobian.org could not connect. I have also checked mobian.org and it seems down for the last three days. Any help??
same here, cannot connect (111:  Connection refused) error doing package update
https://blog.mobian-project.org/ also :-(
Server problems, see https://fosstodon.org/@mobian/112247743295779309
  atinout binaries for mobian/debian? NeutralGrey 2 117 05-13-2024, 02:42 PM
Last Post: Gumur
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,824 05-09-2024, 03:08 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 171 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,133 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,905 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 666 09-01-2023, 11:29 AM
Last Post: Mahgue
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,766 08-31-2023, 12:38 PM
Last Post: vusra
  how to update mobian over tor vusra 13 7,186 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,967 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 662 07-05-2023, 03:57 AM
Last Post: paulcarton
