Link USB power strips for a cluster?
So Im thinking of building a Pine64 cluster for a homelab over a Pi for a couple reasons, also being able to order more than one of the same type.
Their website sells USB to barrel power adapters awesome! But I need a power strip that can output 5V 3A for at least four USB ports.
I am not honestly that familiar with power usage and finding pieces but I see a lot of 2.4Amps with a max total of 12Amps. Out of a USB power strip. Is 3A really just 2.4?
192.168.0.1 routerlogin 192.168.l.l
(07-22-2021, 11:03 AM)DevonBirch Wrote: So Im thinking of building a Pine64 cluster for a homelab over a Pi for a couple reasons, also being able to order more than one of the same type.
For for 5V 3A USB ports, check out PinePower 120W desktop supply
If you have one floating around, you might also use an atx pc power supply. On the 5v rail, they can normally deliver 20A. A molex to micro usb cable is included.
https://router-address.com/
https://whatmyagenow.com/
Here are some examples of USB power strips that could be used to power a cluster:
1. Anker PowerPort Cube: This is a compact power strip that features three AC outlets and three USB ports, making it a good choice for powering a small cluster of devices.
2. Belkin SurgePlus: This power strip features six AC outlets and two USB ports, providing plenty of power and connectivity options for a larger cluster of devices.
3. Tripp Lite TLP606USB: This power strip features six AC outlets and two USB ports, as well as surge protection to help protect your devices from power surges.
4. AmazonBasics 6-Outlet Surge Protector: This is a basic power strip that features six AC outlets and two USB ports, making it a good choice for a small cluster of devices.
When choosing a USB power strip, make sure to consider the power requirements of your devices and ensure that the power strip can provide enough power to meet those requirements. Additionally, consider the length of the power cord and the placement of the devices to ensure that the power strip can be conveniently located to power all the devices in the cluster. Drift Boss
When it comes to power strips that include USB ports, it is essential to have a thorough understanding of the power output requirements and how these specs relate to the electronic devices that you intend to connect.geometry dash unblocked
Lightbulb Product idea: Pinebank, 18650 multifunction power bank/speaker/light/etc cowsay 0 262 10-03-2025, 11:35 AM
Last Post: cowsay
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 2,183 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Replacement international plugs for 65W GaN Pine Power Cadair 1 2,379 05-20-2025, 10:20 PM
  Plans for higher Power PinePowers PMARC14 1 3,294 04-08-2025, 08:31 PM
Last Post: colajuices
  Pine Desktop PowerSupply wont power on BSharp 6 5,878 01-07-2025, 08:04 AM
Last Post: skare
  Help with high voltage power supply setup for electrospinning? namarang 3 3,861 12-11-2024, 09:47 PM
Last Post: NovaSpindle_X
  Firmware Update for PinePower Desktop Power Cycling Issue TimothyRodriguez 1 2,087 05-03-2024, 12:53 AM
Last Post: Pavlos1
  Link USB power strips for a cluster? shanefe 1 2,036 04-02-2024, 11:11 PM
Last Post: evilbunny
  Im thinking of building a Pine64 cluster Theirat1991 1 2,603 01-12-2024, 03:31 AM
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 1,901 09-02-2023, 10:13 AM
Last Post: lupyuen
