Centos 8 Stream on Rock64
So I followed along the guide to install CentOS 7 referenced on the Wiki (and noted on the thread here: https://forum.pine64.org/showthread.php?...&pid=95685 and the guide on the developer's site here: https://project31.github.io/pine64/), and decided to give upgrading to CentOS 8 and then switching to Stream a try.
I followed a few guides online (specifically here https://www.tecmint.com/upgrade-centos-7-to-centos-8/ and here https://linux.web.cern.ch/centos8/docs/migration/), and with a tad extra fiddling to handle the kernel version, I was able to get fully updated and now am booting into CentOS stream!
My question is that upgrading 7 - 8 isn't technically supported, so I would like to try making an updated image for Stream 8.
The Project31 site has some info linking to it's inspiring project, which mentions taking the AArch64 image and a booting Armbian image and swapping out the rootfs bits while preserving the the /boot, /lib/modules, and /lib/firmware (here: https://github.com/umiddelb/aarch64/wiki...ch64-board)
When I try to follow up on this, I cannot seem to figure out how to take the images available on the CentOS site and extract the rootfs.... Can anyone point me in the right direction?
Thank you for your help, and your patience!
Have you tried the procedure that works with CentOS 7?
https://www.thegeekdiary.com/centos-rhel...itview-it/
it doesn't get happy
it doesn't get sad
it just runs programs
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,373 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 619 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 613 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,428 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,760 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 593 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,466 12-07-2022, 08:22 PM
Last Post: luminosity7
