Pinephone BE keeps locking itself when unplugged
Got the PinePhone BE yesterday and have a very annoying issue.
All of a sudden it started locking it self down after a few seconds of unplugging the charger.
It then shows the lock screen. If you enter the pin it will work for a few seconds and then the same happens again.
If plugging it in, the phone keeps working just fine.
For now i could only fix it by simply removing the lock screen command:
sudo mv /usr/lib/kscreenlocker_greet /usr/lib/kscreenlocker_greet.bak
But why is this happening???
EDIT:
After the file was renamed the keyboard still kept dissapearing.
Since i saw the post right below this one was "not to use the Display section of Settings" and that was exactly what i had done to increase the timeout.
I have since fixed this issue by performing the file changes of https://forum.pine64.org/showthread.php?...8#pid93468 and then renamed the kscreenlocker_greet file back to its original name.
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 8,342 Today, 12:01 AM
Last Post: spazz
  New PinePhone user issues greenpineuser 5 339 09-01-2024, 09:37 AM
Last Post: jakfish
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 312 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 809 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 938 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 2,557 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 3,469 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 9,335 02-04-2023, 08:35 PM
Last Post: Westslope
  Pinephone craches after each call neithan76 2 1,965 07-29-2022, 11:47 AM
Last Post: Chief
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 33,499 07-28-2022, 12:40 PM
Last Post: johaennessen
