Pine power firmware
Hi
There are some elements of the display behaviour on the pine power I dislike. Is the firmware opensource so that I can fix it, please?
What do you dislike?
The wiki does not document any firmware, just an image showing the rear of the LCD panel -- there are two unmarked ICs (U4 and U5). I do not know if these are re-programmable it may be a difficult process even assuming the programming could be re-applied (they may even be programmable only once).
The screen power down behaviour mostly - if the PSU is on, I want the screen to stay in unless I press the screen off button, and if the screen is off then I want the screen off button to turn it back on.
Currently I have to physically look at the power switch to tell if it is on, and the screen sometimes comes on when wireless charging and sometimes doesn't
  A post about a Pine-64 Wi-Fi ethernet router project board and enclosure? Omnios 1 378 09-21-2023, 07:52 AM
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 477 09-02-2023, 10:13 AM
Last Post: lupyuen
  Is it possible to use Pine-64 board as a Mini PC such as BeeLink? Omnios 1 566 08-30-2023, 04:23 PM
  Pine Desktop PowerSupply wont power on BSharp 5 1,316 08-29-2023, 08:06 AM
Last Post: chickenplusone
  power/battery usage on risc-v vs arm64? zetabeta 1 510 08-28-2023, 01:23 AM
Last Post: alphonso
  Link USB power strips for a cluster? DevonBirch 4 2,994 08-10-2023, 09:11 PM
Last Post: halibutdreary
  Possible new Pine64 product - Pine Blue Ray DVD Linux tv box Omnios 5 1,029 07-24-2023, 03:21 PM
Last Post: Omnios
  Plans for higher Power PinePowers PMARC14 0 406 07-14-2023, 03:03 PM
Last Post: PMARC14
  Pine.org very poor review rma00 6 1,215 06-30-2023, 12:52 PM
Last Post: gregb49
  The power of the Star64 vs Pinebook Pro/RockPro64 Starfall 1 930 04-17-2023, 05:00 AM
Last Post: lkoini
