Pine power firmware
Hi
There are some elements of the display behaviour on the pine power I dislike. Is the firmware opensource so that I can fix it, please?
What do you dislike?
The wiki does not document any firmware, just an image showing the rear of the LCD panel -- there are two unmarked ICs (U4 and U5). I do not know if these are re-programmable it may be a difficult process even assuming the programming could be re-applied (they may even be programmable only once).
The screen power down behaviour mostly - if the PSU is on, I want the screen to stay in unless I press the screen off button, and if the screen is off then I want the screen off button to turn it back on.
Currently I have to physically look at the power switch to tell if it is on, and the screen sometimes comes on when wireless charging and sometimes doesn't
  Link USB power strips for a cluster? shanefe 1 220 04-02-2024, 11:11 PM
Last Post: evilbunny
  pine vacuum cleaner and door phone norayr 3 607 01-16-2024, 02:31 AM
Last Post: hanajijang
  Android OS that supports LCD touch panel (pine a64) Spekboy 0 372 01-14-2024, 01:41 PM
Last Post: Spekboy
  A post about a Pine-64 Wi-Fi ethernet router project board and enclosure? Omnios 1 610 09-21-2023, 07:52 AM
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 674 09-02-2023, 10:13 AM
Last Post: lupyuen
  Is it possible to use Pine-64 board as a Mini PC such as BeeLink? Omnios 1 798 08-30-2023, 04:23 PM
  Pine Desktop PowerSupply wont power on BSharp 5 1,804 08-29-2023, 08:06 AM
Last Post: chickenplusone
  power/battery usage on risc-v vs arm64? zetabeta 1 779 08-28-2023, 01:23 AM
Last Post: alphonso
  Link USB power strips for a cluster? DevonBirch 4 3,452 08-10-2023, 09:11 PM
Last Post: halibutdreary
  Possible new Pine64 product - Pine Blue Ray DVD Linux tv box Omnios 5 1,525 07-24-2023, 03:21 PM
Last Post: Omnios
