Change locking of Ctrl modifier?
I'm really used to the Ctrl modifier only applying to the single keystroke which follows it.  Instead, Ctrl behaves like a caps lock, staying applied until you click it again.  I'm sure that's great for some, but not me.
I've had a swing through the Squeekboard documentation, and but I really don't see anything in the config file to control this.  Has anybody addressed it?  TIA.
The locking ctrl key drove me nuts for about a week or so. Smile  I never found a solution or workaround and occasionally I would think phosh or debian had crashed or become unresponsive only to discover that I left the ctrl key on. However that problem has gone away and I didn't really notice until I read your post Big Grin  .   I just got used to de-selecting the ctrl/alt key as part of the key combination sequence, atomatonamously. Mostly, squeekboard is excellent but I would like an option to release all the modifier keys when it drops into icon view, that would be super cool . Cool
Cheers!
  Change GUI from Phost to Gnome (or anything else) johnpine 0 1,699 05-27-2022, 06:52 AM
Last Post: johnpine
  User login change usagi 11 11,716 05-13-2022, 01:16 AM
Last Post: johnpine
  Change default program for a file type 3x5co 1 2,985 09-01-2021, 05:26 PM
  How to change the minimum password length when changing from default passwords arturo2bodegas 3 7,032 07-18-2020, 01:51 PM
Last Post: arturo2bodegas
  power management change? pjsf 1 4,836 06-05-2020, 05:16 PM
Last Post: a-wai
