Moving lines on screen
Does anyone else have the issue of, or does someone have a solution for, ghosting lines on the PineTab screen?
One day I turned it on and there is a section of the screen where short lines move across the display, and really ruin the visibility/experience.
I've hit it with a hammer, that didn't work. What else can I try?
TIA
(04-29-2021, 08:20 PM)SpoofyKid Wrote: I've hit it with a hammer, that didn't work. What else can I try?
TIA
Overrun it by a truck? Cool
Maybe check the connector to the display
(04-30-2021, 04:42 AM)guenther Wrote: Overrun it by a truck? Cool
Might have to.
I took out the display ribbon, and put it back in, no luck. I hate taking the back off for fear of something else breaking, but I'll try again - maybe I'll blow on it this time, like it's a Nintendo game cartridge.
Thanks.
(04-30-2021, 05:06 AM)SpoofyKid Wrote: I hate taking the back off for fear of something else breaking...
I haven't did it yet but I feel with you...
Well, I don't think it's OS related but have you tried a different one? Or plug it to a monitor? Without spare parts (if there are any available in the future) to test it's hard to tell what's the issue. Will be hit and miss I guess.
Sorry I can't help. Good luck.
And put away the hammer! Big Grin
Can you share pictures of what you're seeing?
I think I heard something similar with a PinePhone, might be worth checking out the forum threads over there as the hardware is very similar.
Thanks for the ideas.
I'll check out the PinePhone threads.
I've tried it on Ubuntu too, and had no luck. It just one day started happening.
I don't have an HDMI out cable to try it, though I'm pretty certain it's a hardware issue.
With an LCD shortage, a replacement screen isn't possible according to support.
  Pinetab2 screen removal Corconegre 5 1,349 01-10-2024, 08:08 AM
Last Post: stozi
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 542 09-28-2023, 01:06 PM
Last Post: dynobang
  PineTab2 screen won't turn back on until reboot KelsonV 3 1,056 08-23-2023, 09:08 AM
Last Post: diederik
  Pinetab 2 screen no longer coming on Fibonacci 9 2,992 06-30-2023, 08:26 AM
Last Post: Purple_Illusion
Big Grin Howto: Pinetab Screen Replacements (+ Pictures) RTP 5 6,432 02-10-2022, 08:31 PM
Last Post: barray
  Possible screen resolution upgrade in the next batch? marcinus 2 3,658 07-19-2021, 09:14 AM
Last Post: swiley
  Replacement Screen Options NerdyOwl 0 2,238 10-18-2020, 10:53 PM
Last Post: NerdyOwl
  Opening the back and screen cracks quipacorn 0 2,214 10-12-2020, 01:01 PM
Last Post: quipacorn
  PineTab Screen Protectors bcnaz 1 2,611 08-23-2020, 11:03 PM
