copy/past/ firefox/mobian
It drove me crazy not being able to past code into terminal from firefox. Somehow I figured it out. I'm sure there is a more elegant way of doing it but this works.
What ever you want to copy, highlight it.
bring up keyboard and type  copy  and hit return.
go to the globe at bottom left of keyboard
select terminal.
tap on < icon bottom right.
tap on menu
you will see a tab open up
tap on copy.
ignore page it pops up.
go to terminal
long press on curser
tab will pop up
tap on past.
As with many thing with pinephone, its a little glitchy, sometimes you will have to do this twice and yes it kind of a pain but its a lot better than entering stuff manually. Also this gives you a way of storing data on phone. Instead of ignoring the download page, you can past to there.
I hope this helps.
The Firefox "hamburger menu" (3 horiz lines top right) has 3 icons under the zoom controls for cut, copy and paste.
Also you can switch to the Terminal Keyboard (via globe key menu) and use CTRL C, CTRL X or CTRL V.
EDIT:
I'm not 100% sure about this one but I think Firefox also has an option to automatically copy selected text.
  I must have dreamed up that option Big Grin . After a look through the settings I can't seem to find it.
Cheers!
(04-21-2021, 08:23 AM)MtnSk8 Wrote: The Firefox "hamburger menu" (3 horiz lines top right) has 3 icons under the zoom controls for cut, copy and paste.
EDIT:
Cheers!
way cool, a lot easier. thanks.
  pinephone-support package not upgradable on Mobian fhireman 5 6,383 02-28-2026, 05:49 PM
Last Post: baptx
Exclamation No wIfI after Mobian update crakabeats 5 6,433 02-28-2026, 04:18 PM
Last Post: baptx
  What is wrong with the Mobian signature key? Mahgue 0 769 11-08-2025, 05:13 AM
Last Post: Mahgue
  Clamares password needed with new Mobian installation fauvetan 1 2,604 06-26-2025, 03:00 AM
Last Post: merom
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 13,190 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 30,951 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 7,606 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  No sound after Mobian upgrade arbocenc 1 2,550 11-28-2022, 11:02 AM
Last Post: arbocenc
  No Firefox? MarsColonist 3 4,140 05-21-2022, 08:20 PM
Last Post: epiii2
  PinePhone running Mobian - Malware extraction? names_fold 1 3,243 01-24-2022, 12:00 PM
