Software/Notifications
Possibly I'm doing something very wrong here but I have disabled the notifications in "Settings" for "Software", and when I launch "Software" I also disabled the automatic updates and the notifications. The result of my changes is that not only does "Software" check for updates, but also I still get notifications. Is there a fundamental misunderstanding on my side or do I have to file a bug somewhere?
Right, I have removed the gnome software app, this takes care of the problem. I have not had any issues so far and it removes only 3 packages, so I can recommend this solution for anyone who prefers apt, as I do.
(04-30-2021, 02:07 AM)battlegarden Wrote: Right, I have removed the gnome software app, this takes care of the problem. I have not had any issues so far and it removes only 3 packages, so I can recommend this solution for anyone who prefers apt, as I do.
+1
I too find it confusing, ineffective and completely unintuitive. And yes, the first package I remove after any install that has it.
+1
While I make updates through apt in the terminal, I've kept the GNOME Software app. Reason in two words: software discoverability.
Discoverability sucks using the CLI, plain and simple, if you don't already know the package name.
GUIs do have their use.
There is the option to keep gnome software but be much less annoyed by it:
https://wiki.mobian-project.org/doku.php...app-drawer
Big Grin
  Why is Firefox ESR not listet under "Installed" in "Software" jojuma 0 555 08-30-2023, 03:23 PM
Last Post: jojuma
  Sound : notifications freelectro 6 1,746 06-07-2023, 01:03 AM
Last Post: freelectro
  PinePhone won't boot after software update jb2000 2 1,251 03-17-2023, 07:26 AM
  Does tow-boot allow periodic wake from suspension to check for notifications? DrPlamsa 4 2,547 12-31-2022, 10:56 AM
Last Post: DrPlamsa
  Software update missing on desktop MikeMan 1 1,400 01-27-2022, 06:10 AM
Last Post: bcnaz
  Customized Notifications - Non-native Apps arno_nuehm 2 2,194 10-05-2021, 09:42 AM
Last Post: kqlnut
  No notifications on lock screen DrPlamsa 16 7,885 08-21-2021, 05:35 AM
Last Post: bcnaz
  A clear all button for notifications is coming! ragreenburg 0 1,274 08-13-2021, 09:09 AM
Last Post: ragreenburg
  Phone Shell and Dismissing Notifications on Mobian publiclewdness 0 1,392 04-10-2021, 01:41 PM
Last Post: publiclewdness
  Is there a list of software/Hardware errors Franze_m 6 4,996 02-24-2021, 12:07 PM
