Raspberry pi + Pinetime
Would the raspberry pi be able to sync the time and date on my time? I’d yes would anybody be able to recommend any apps that would be able to do it? I have heard of gadgetbrodge but I don’t think that is on the pi or I haven’t seen any videos or info on it
You could try amazfish - I believe it's no longer tied to Sailfish. Not sure how easy it is to build on the Pi, but it should be possible.
https://github.com/piggz/harbour-amazfish
I was able to do it using the bluetoothctl instructions on the FAQ:
https://wiki.pine64.org/wiki/PineTime_FA...ineTime.3F
(03-04-2021, 11:00 AM)wibble Wrote: You could try amazfish - I believe it's no longer tied to Sailfish. Not sure how easy it is to build on the Pi, but it should be possible.
Thanks dude will ask around on the pi forums incase any of there devs have maybe come up with some beforehand Smile thanks man
  Open-Source Support for PineTime LTE (eSIM) emilyjohnson63 2 2,231 11-01-2025, 05:55 PM
Last Post: euiccc2025
  Migrating to PineTime from a Fitbit dhdurgee 0 2,928 09-25-2025, 12:41 PM
Last Post: dhdurgee
  Brand new sealed Pinetime boot loop elver 0 9,918 09-10-2025, 06:41 AM
Last Post: elver
  Pinetime Black Screen philipallmon 1 4,371 07-30-2025, 11:44 PM
Last Post: karthick
  ? Introducing RoutineHero: A PineTime Smartwatch for Kids' Routines + Companion App oscar-gardiazabal 2 1,316 07-29-2025, 04:49 AM
Last Post: oscar-gardiazabal
  Making watch vibrate using Python from a Raspberry Pi YoungRechnitz 0 1,047 03-27-2025, 03:51 PM
Last Post: YoungRechnitz
  PineTime charging issues - connecting pins black gsoundsgood 2 2,495 09-15-2024, 02:59 PM
Last Post: gsoundsgood
  How do I clear all personal data from the pinetime smartwatch? taltamir 6 3,911 08-22-2024, 10:34 AM
Last Post: taltamir
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 3 7,902 06-25-2024, 12:21 AM
Last Post: Amen
  PineTime at FOSDEM jmlich 5 4,737 02-07-2024, 11:48 PM
