Working modem?
#31
Only other possible thing i can think of is an intermittent connector in the sim tray.
(03-03-2021, 07:37 PM)Barugon Wrote:
(03-03-2021, 07:15 PM)rocket2nfinity Wrote: Have you physically opened the case to see if the antenna connector is connected? It's the long cable on the left, snaking down from the main board to the usb board.
I assume you mean take out the screws and really open it up. I have only taken the back off to get at the microSD and SIM cards.
[edit] Yeah, it's connected.
Just to mention that my mobile connection became intermittent, and the cable _seemed_ to be on okay, but then I removed it and put it on again anyway, and it's been solid since then.
(03-04-2021, 10:18 AM)desca Wrote: Just to mention that my mobile connection became intermittent, and the cable _seemed_ to be on okay, but then I removed it and put it on again anyway, and it's been solid since then.
I'll give that a try.
Have you tried a different SIM? A lot of folks are having serious trouble with AT&T.
(03-04-2021, 07:44 AM)rocket2nfinity Wrote: Only other possible thing i can think of is an intermittent connector in the sim tray.
I think this is part of the problem. If I wedge a piece of folded paper behind the sim card when I insert it then I'm pretty easily able to get a 3G connection at least.
  4G VoLTE calls confirmed working with carrier x dcinoz 15 11,623 03-09-2024, 11:38 PM
Last Post: dcinoz
  Modem white list aular 7 801 02-13-2024, 04:35 PM
Last Post: aular
  qcell modem id aular 6 776 01-15-2024, 10:05 PM
Last Post: aular
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 2,057 07-16-2023, 11:14 AM
Last Post: kebab
  Modem gets disabled on every suspend jojuma 5 1,760 03-27-2023, 02:51 AM
Last Post: jojuma
  Modem audio settings jack1 2 1,283 02-04-2023, 04:01 PM
Last Post: jack1
  MMS sending stopped working amindfv 2 1,211 01-16-2023, 09:44 PM
Last Post: treebeard
  Instructions to get pinephone working on USA carrier omarcomputing 1 1,336 10-08-2022, 04:45 PM
  JumpDrive isn't working phytocube 2 1,752 06-05-2022, 03:22 PM
Last Post: phytocube
  The modem switch affects the connection to battery? JohnDoe 2 1,997 03-30-2022, 12:02 AM
Last Post: JohnDoe
