Microphone not working on Pinebook Pro
I recently discovered that my microphones are not working. I'm on manjaro testing. Has anyone a working microphone on the Pinebook Pro? If so, which distro are you using?
regards,
Hans-Peter
(02-07-2021, 04:33 AM)vfr400racer Wrote: I recently discovered that my microphones are not working. I'm on manjaro testing. Has anyone a working microphone on the Pinebook Pro? If so, which distro are you using?
regards,
Hans-Peter
Im on Manjaro-ARM kde:5.21.1, kernel:5.7.19
I am having the same issue. I followed the instructions here:
https://wiki.pine64.org/index.php/Pinebook_Pro
Went so far as to taking it apart. I traced to the wiring to the taped holes.
Currently it is not showing up on pavucontrol nor elsewhere.
Help!?
Thanks in advance!
Braan
regards,
Hans-Peter
Help!?
Thanks in advance!
Braan
 I tried another image. I can't remember, if it was mrfixit's or ayufan's image. I got microphone input with that. So it's not the hardware in my case. Seems as if Manjaro is missing microphone support .
  Replacement battery for PineBook Pro DrYak 5 6,075 02-28-2026, 09:17 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 5 7,635 01-02-2026, 04:26 AM
Last Post: stu73
  pinebook pro dixplays vertical stripes WEF 2 3,402 03-23-2025, 03:31 PM
Last Post: WEF
  New Working nVME gilwood 1 3,070 11-17-2024, 04:24 AM
Last Post: reukiodo
  Yet another new Pinebook keyboard problem MikoBob 3 3,964 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 3,545 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 3,502 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 3,047 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 207,283 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 13,220 01-18-2023, 07:41 PM
Last Post: ottahe
