Chromium doesn't seem to recognize that I'm on a mobile device
Until recently, Chromium was unusable on Mobian. I'm happy to say that it has quickly pulled into the lead for most usable Mobian browser. However, it often serves up the full, desktop version of siteswith a big, horizontal scroll bar.
Some sites display in the correct, responsive layout. But Google, for instance, runs off the page. Any idea why this is, and how to force it render sites properly?
Probably some websites assume that "if the UserAgent doesn't suggest that it's a mobile OS or mobile browser, then it has to be a desktop, no doubt about that!!".
Mobian is technically a mobile OS, but the Chromium you run on it is still the desktop version, so I guess in this case you'll need to manipulate the UserAgent (I'm using Qutebrowser which has this functionality built in, but Chromium has extensions for that).
Responsive websites will make use of the screen size, so you'll get to see the "mobile version" regardless of the UserAgent.
Don't ask me what UserAgent you should set it to, I don't bother with that.
I actually prefer the "desktop version" of websites anyway, since that's often the version that doesn't strip away useful information or functionality just to prevent people from scrolling horizontally.
母語は日本語ですが、英語も喋れます(ry
Thank you, changing the user agent fixed this problem!
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,962 01-15-2025, 08:08 PM
  Alarm clock doesn’t work Captain1ndustry 13 23,819 12-15-2024, 07:07 PM
Last Post: baptx
  The program doesn`t detect the camera blag0rag 6 4,453 09-17-2024, 03:45 PM
  Mobile internet via cellular network mostly not working Anna 18 20,301 01-19-2024, 02:59 AM
Last Post: anonymous
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 5,539 09-05-2023, 11:16 AM
Last Post: nickolas
  Wifi doesn't work after update nickolas 2 3,350 04-14-2023, 10:07 AM
Last Post: nickolas
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 3,875 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 3,514 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 6,380 12-01-2022, 09:18 AM
Last Post: traut
Exclamation The webcam doesn't work in Firefox anonymous 0 1,688 11-06-2022, 01:45 PM
