Pinecil rattle?
Just received my pinecil from the 2nd production run, and something is loose inside it?
It's not just the buttons - if i hold both of them down and shake it, i can still hear something moving around inside it.
Couldn't resist. Exploratory surgery suggests that the only thing that could possibly be loose is the outer contact ring in the DC barrel, which is perfectly fine because it's a spring.
Just got mine today, it has the same rattle. Maybe this is normal since my Pinecil seems to work just fine, the rattle sound is not that noticeable to me. It should be easy to tear down and see what it is, but I don't want to ruin the grip.
Got mine today and it has a rattle to it also. Pulled it apart and it seems to be something inside the DC barrel jack or the USB port. Iron functions as expected over USB-C however. Unable to test the DC barrel jack.
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 0 17 04-23-2024, 01:48 PM
Last Post: Garywoo
  Connecting a power supply to the Pinecil jon_bondy 1 373 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 782 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 368 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,262 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 662 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,286 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,549 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,444 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,244 12-14-2022, 01:03 AM
Last Post: River
