Geary crashes during start after recent update
Hello folks,
I was so happy how nicely is geary working in mobian.
Did today apt-get update and apt-get upgrade, and since then geary fails to start. the error is
*[wrn] 23:31:27.0612 geary:application-certificate-manager.vala:74: No GCR slot URIs found, GCR certificate pinning unavailable
![crt] 23:31:28.0963 GLib:Did not see expected message GLib-GObject-WARNING **: g_object_weak_unref: couldn't find weak ref *
*[wrn] 23:31:28.0963 GLib-GObject:invalid (NULL) pointer instance
Trace/breakpoint trap
I consider this pretty important, since it was the only client so far working nicely and being really usable.
Attached is the relevant par of dpkg.log
Any idea? How to at least restore it.
.log   todays_upgrade_dpkg.log (Size: 106.74 KB / Downloads: 472)
(01-12-2021, 04:39 PM)p1trson Wrote: Hello folks,
Try this → https://bugs.debian.org/cgi-bin/bugrepor...=978146#10
Seeing the date this was reported, it doesn't seem like it's the first time this bug has happened.
母語は日本語ですが、英語も喋れます(ry
Cheers Ryo, should have probably googled more ^^
Yup can confirm that doing what's described in the above link did allow me to start the Geary again. Ofc whole configuration was lost.
  trixie update poll questions suggestions j_s 5 467 10-22-2025, 07:14 AM
Last Post: anonymous
  New Install, apps start but don't show up on screen?! RT3 2 1,798 07-18-2025, 07:56 PM
  how to update mobian over tor vusra 14 15,352 12-04-2024, 07:01 PM
Last Post: vusra
  Errors when start the system kubussz 2 2,613 11-21-2023, 11:07 AM
Last Post: kubussz
  Auto start application on Phosh login Zebulon Walton 8 9,037 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Wifi doesn't work after update nickolas 2 3,350 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 3,581 03-17-2023, 07:26 AM
  Most recent Mobian image or installer image known to work? DrPlamsa 13 11,946 02-26-2023, 11:47 PM
Last Post: SukiiPooru
Exclamation Impossible to login since the latest update anonymous 12 11,693 02-26-2023, 01:01 PM
  Recent install, no wifi user641 3 3,617 01-12-2023, 03:06 PM
Last Post: user641
