list of linux native apps/softwares for pinephone on the wiki
Could it be possible to list the linux native apps/softwares for pinephone (or mobile) on the wiki ? They're often distribution independant… Maybe, with a litlle sum up of the working functionalities, a link to some git repo, etc…
Thanks,
alex
I like the idea of there being a central database, but the amount of available apps you can install already is staggering, and each app is at various degrees of usable or broken. I'm not sure even the apps that come preinstalled on each distro are in a state where the devs behind them are satisfied with their performance.
There's tons of moving parts to why apps would not work well either, and sometimes it isn't even the app's fault. Purism's Phosh is still pretty rough around the edges.
It would be awesome though if someone in the community with web-dev experience were to make a community website like https://appdb.winehq.org/ or maybe https://www.protondb.com/ , where everyone can test apps and contribute easily.
There is a page on the Mobian wiki with some apps that work
https://wiki.mobian-project.org/doku.php?id=apps
I'm not sure if it's quite what you're looking for but I find it very useful
There are such lists for Librem 5, and the apps should work at least on a Pinephone with Phosh:
https://source.puri.sm/Librem5/community...evelopment
https://tracker.pureos.net/w/pureos/mobi...ized_apps/
(01-04-2021, 08:14 AM)fsflover Wrote: There are such lists for Librem 5, and the apps should work at least on a Pinephone with Phosh:
That helps, thanks. On the first page there's also a link to
https://mglapps.frama.io/
(01-01-2021, 06:57 AM)alexandre Wrote: Hi,
Thanks,
alex
sudo apk info -v | sort | more
Will give you all packages on your OS.
Shameless self-plug as my project is not listed here yet (it's a fork of MGLapps): https://linmobapps.frama.io
Thanks,
alex
The  Mobian  'Software Store' has something similar,    some of the available software Apps say :  'SAFE reviewed by your distribution'.
These have links to their project websites
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  PinePhone - boot from microSD laserpyramid 6 535 04-22-2024, 02:22 AM
Last Post: bongosunny
  pinephone virtual keyboard aular 4 339 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 228 04-02-2024, 11:50 AM
  Writing apps/programs for pine phone katesfb 7 5,049 03-11-2024, 10:42 PM
Last Post: Emelia525
  Are you using the Pinephone as your daily driver? jro 157 108,870 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,776 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  Modem white list aular 7 887 02-13-2024, 04:35 PM
Last Post: aular
  pinephone is not bootble for the box. ijij 1 599 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,333 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 490 12-26-2023, 02:42 PM
Last Post: shengchieh
