10-22-2021, 02:02 PM
Image has been updated to ship latest DietPi v7.7 based on Debian Bullseye: https://dietpi.com/downloads/images/Diet...ullseye.7z
DietPi OS for ROCK64
10-22-2021, 04:06 PM
Thanks, Michalng for the update.
I'm running v7.7.3 on (on Buster) on Rock64. Thanks for the amazing DietPi. The main purpose is to run Wireguard Server & get access to the home network from outside. Working great with no issue. (1) Can I update to Bullseye? If yes, How? Do you recommend a new fresh install? (2) Lately, home internet had frequent disconnections (ISP problems). I added an android cell phone with USB tethering. It does show in the list usb0 when I run "ip addr" but no network traffic. it's 4th on the list. I want to use it as FALL BACK if the main internet (eth0) is not working & want to access the home network via Wireguard over USB tethering.
10-23-2021, 06:56 AM
(This post was last modified: 10-23-2021, 09:44 AM by MichaIng.
Edit Reason: Typo
Many thanks for your kind feedback.
For migration to Bullseye, generally we recommend to flash a fresh image, which is the overall cleaner method. But you can also do a distro upgrade where we wrote a guide about: https://dietpi.com/blog/?p=811 We try to cover all issues that can arise and update the guide accordingly, but there is no 100% guarantee that no manual tinkering is required, like updating configuration files when the related software package had a breaking change. For WireGuard however there is no surprise expected. For USB tethering, not sure how you set it up currently, but I suggest to create a dedicated configuration like /etc/network/interfaces.d/usb0.conf and configure the static IP and gateway there. With "allow-hotplug usb0" it would then be brought up at boot when the actual adapter is attached (the interface found by the kernel), otherwise it is ignored. Or a background service which regularly checks connectivity through the regular interface and brings up USB tethering as fast as connection is lost. Checking for ISP connectivity while you're using USB tethering could be however a little challenge .
10-23-2021, 09:40 AM
Thanks, Michalng for the detailed reply.
I will try in this direction.
11-25-2021, 01:18 AM
bought the rock64, in purpouse of running kodi on it.. flashed dietPi, and kodi barely runs.. cannot start without ```sudo``` and cannot add new plugins from kodi repository, that's one of the issue. @MichaIng can you help?
For running Kodi as unprivileged user, try to add it to video, render and audio system groups, if you you want to start it from a different console (e.g. call it via SSH to show up on main screen without a keyboard attached), as well tty group:
Code: usermod -aG video,render,audio,tty skywayFor plugins, try to install the addons repository package: Code: apt install kodi-repository-kodi
11-25-2021, 07:17 AM
(This post was last modified: 11-25-2021, 07:17 AM by skyway.
Edit Reason: md
Quote:We should probably install this by default, or at least give a hint, as most users want to use it, I guess? or at the least make it so that when ```kodi``` is chosen from ```dietpi-software```, to trigger the installation of the package.. will test and report if what you said solved my problem
11-25-2021, 07:49 AM
11-26-2021, 03:23 AM
i set up Kodi to autostart from dietpi autostart, and cannot control it via web, or via keyboard/mouse. The messange being displayed on Kodi is regarding the version.. something like "Using 19.1 but 19.3 is available".. an that's that. Frozen.
The web interface is by default disabled since Kodi 19, but can be enabled via GUI. Yes it's Kodi 19.1 since this is what Debian ships on Bullseye: https://packages.debian.org/bullseye/kodi
If keyboard and mouse do not work, that's of course a problem. Is it the same when simply calling the kodi command or kodi --standalone from command line? As you found out about the missing plugin repository, obviously input worked at first. |
| Xen hypervisor on Rock64 | tumbleweed | 6 | 9,684 |
Yesterday, 09:25 AM Last Post: darkfader |
| irradium (based on crux linux) Rock64 riscv64, aarch64 | mara | 9 | 15,792 |
07-20-2025, 01:00 PM Last Post: mara |
| Rock64 - not booting after Armbian update | helpmerock | 6 | 3,656 |
03-27-2025, 08:26 AM Last Post: wdt |
| can rock64 4gb ram run entirely on free software? | heocb | 1 | 2,358 |
01-07-2025, 05:47 AM Last Post: KC9UDX |
| Upgrading ancient Rock64 | timxjr1300 | 1 | 2,487 |
11-26-2024, 09:47 AM Last Post: dmitrymyadzelets |
| arch rock64 does not boot | nemnob | 1 | 3,516 |
09-20-2024, 11:18 AM Last Post: AwU2HBg |
First Lakka image for Rock64! | Luke | 47 | 100,220 |
09-01-2024, 06:05 AM Last Post: RaymondDay |
| Rock64 v2 - did not work song / audio | sqw200zu | 2 | 4,437 |
03-14-2024, 03:09 AM Last Post: dmitrymyadzelets |
| Rock64 won't boot | dstallmo | 0 | 2,608 |
12-27-2023, 10:34 AM Last Post: dstallmo |
| HDMI doesn't work on rock64 | Noung1991 | 1 | 3,076 |
11-21-2023, 08:33 AM Last Post: as365n4 |
