Axolotl on PinePhone / Mobian
I just noticed that I can no longer send OR recieve pictures via Axolotl (using the latest available .deb-Version "axolotl_1.5.0-1_arm64.deb"). Two days ago recieving still worked (sending is broken for longer) - Do others have the same problem? Did Signal again change something? Sad
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
Just in time:
v1.6.0 is out with plenty of fixes - also for your bug, dante404 (Signal renewed their root ca-cert in the last days).
Download&Installation via
wget https://github.com/nanu-c/axolotl/releases/download/v1.6.0/axolotl_1.6.0-1_arm64.deb && sudo apt install ./axolotl_1.6.0-1_arm64.deb
Backup of the textsecure.nanuc folders in .local/share and .config is recommended since a lot changed in the background.
nanu-c and Blackoverflow did a great job here!
Cheers!
P.S.: First start of v1.6.0 might take a while in order to download the electron binary - as usual ~80Mb.
EDIT: Old chats are not lost. Wait for the counterpart to send a message, then the chat history is back.
(10-27-2022, 03:31 PM)arno_nuehm Wrote: Just in time:
Awesome! Big Grin
Thank you for letting us know!!!
Everything is working again as before (sending and recieving images), some missing old messages (text and pics) were also recieved now. Smile
Didn't work for me. It just flatly kept telling me it can't connect to Signal's servers, perhaps I should unregister and register again.
The captcha is frustrating, the images are so small that it took me quite a while to get through, but eventually I did. Then it told me to enter the six digit code. Well, last time, in early september, I got the SMS from signal. This time not.
Next time I launched it just asked me for a username, so I guess it let me pass without. But then when I tried to add someone to the contacts list, nothing happened.
(10-29-2022, 09:16 AM)Eugo Wrote: Didn't work for me. It just flatly kept telling me it can't connect to Signal's servers, perhaps I should unregister and register again.
Sadly, there are some regressions in v1.6.0 regarding the internal data structure and hotfixes are prepared as fast as it is possible.
shulamy Wrote:
i installed version 1.6.0 by editing the PKGBUILD
but the buttons are rendered as colored rectangles without text
i think i saw somthing about rendering problem but i don't find it now
is there a solution?
ezik
I assume, you are using Axolotl on Arch/Manjaro. As written in the previous post, there are some internal bugs to be fixed and the devs are on it. I will try to reproduce your issue with one of the latest Arch/Manjaro images.
Fingers crossed...
wget https://github.com/nanu-c/axolotl/releas..._arm64.deb && sudo apt install ./axolotl_1.6.0-1_arm64.deb
.........for some reason link does not work: error404, file not found?
Hello there,
sadly, I cannot recommend to use Axolotl at the moment. There are too many bugs and regressions to be fixed... The team is working their best, but it'll take some more time to make the app usable again.
Sorry for that...
It's a bit hard to type with fingers crossed, but I'll keep on...
(11-01-2022, 04:02 PM)arno_nuehm Wrote: sadly, I cannot recommend to use Axolotl at the moment. There are too many bugs and regressions to be fixed... The team is working their best, but it'll take some more time to make the app usable again.
Strange, I missed one message (image) the last days (AFAIK), but otherwise it seems to work still OK here (use axolotl every day, chatting with multiple different persons). Huh
BTW thanks for your work on Axolotl! Smile
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 25 2,549 Yesterday, 01:34 PM
Last Post: treebeard
  Mobian repository status henrythemouse 16 8,999 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 160 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,715 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,083 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,890 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 658 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,071 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,938 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 654 07-05-2023, 03:57 AM
Last Post: paulcarton
