Gnome shell - Mobian Resolution
I have installed Gnome-shell following the instructions from: https://wiki.mobian-project.org/doku.php...vironments
The problem I have is that the Gnome environment is not scaled, so not all the icons appear on the screen and some are overlapping.
I can't find a way to fix the Gnome resolution.
Is there a way to do it?
Thank you.
You'll need to configure the fractional scaling setting in Gnome. It's under the Display menu in Settings.
(10-14-2020, 02:28 PM)canaac Wrote: The problem I have is that the Gnome environment is not scaled, so not all the icons appear on the screen and some are overlapping.
See this post - you may also want to stop the services for phosh, serial usb and packagekit if you notice high cpu usage in idle.
(10-14-2020, 03:36 PM)ThrillGates Wrote: You'll need to configure the fractional scaling setting in Gnome. It's under the Display menu in Settings.
Thanks for the answers. Tonight when I get home I try it.
I could not access the Gnome configuration, since due to the bad configuration of the scaling the options did not appear on the screen.
I found the solution in the post that you indicated. With the following command, the interface was perfectly scaled.
gsettings set org.gnome.desktop.interface scaling-factor 1
  Mobian repository status henrythemouse 16 8,748 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 2,005 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 132 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,995 11-22-2023, 11:46 AM
Last Post: aLoop100o
  gnome-control-center: segmentation fault on startup jojuma 4 1,087 09-12-2023, 08:49 AM
Last Post: jojuma
  What actions needed to keep on mobian testing user641 3 1,823 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 633 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,899 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,900 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 631 07-05-2023, 03:57 AM
Last Post: paulcarton
