Yoyo interefering with apt upgrade
The past several times I've tried to do a sudo apt upgrade, I get an error about "yoyo", some python3 package that is apparently installed in two places or some such.
It errors out the upgrade.
I tried "sudo apt upgrade --fix-broken install"... it errored out the same way.
what is "yoyo", and why is it breaking my upgrade?
I have no idea what yoyo is or why its breaking the upgrade. However, I think you will find a fix for the problem in this thread same as I did.
https://forum.pine64.org/showthread.php?...291&page=3
(10-10-2020, 08:00 PM)ergo owl Wrote: I have no idea what yoyo is or why its breaking the upgrade. However, I think you will find a fix for the problem in this thread same as I did.
Thank you; that seems to have fixed it.
Awesome! Smile
  Mobian boot failed with zstd message after upgrade. Mahgue 0 632 09-01-2023, 11:29 AM
Last Post: Mahgue
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,177 03-01-2023, 04:45 PM
Last Post: anonymous
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 987 01-04-2023, 06:46 PM
Last Post: 3x5co
  Receive MMS fails after Nov 27 upgrade treebeard 17 5,911 12-12-2022, 05:09 AM
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 4,045 09-30-2022, 08:53 PM
Last Post: treebeard
  Modem Firmware Upgrade - Modem Busy - USB Issues biketool 10 4,780 09-23-2022, 05:15 AM
  New Tow-boot release, how to upgrade? user641 3 1,885 08-23-2022, 08:45 AM
Last Post: user641
  GPS/location services don't work with Maps after Bookworm upgrade Anna 16 10,169 06-13-2022, 02:37 PM
Last Post: wibble
  Firmware upgrade via fwupd user641 3 2,796 04-24-2022, 11:01 AM
Last Post: yehudac
  Epiphany browser broken after webkit packages upgrade user641 0 837 04-15-2022, 05:20 AM
Last Post: user641
