Best quick/easy way to control case fan speed?
Heart
Hello!
I have this case: https://kksb-cases.com/products/kksb-roc...8bfc&_ss=r
It includes a little fan (which is quite noisy, haha), and it works fine just by using the pins on the board.
But it goes at full blast all the time. I was wondering if you guys could help me figure out a way to have a voltage control setup tied to CPU temp?
I remember seeing something for the RPi with Python, but I can't seem to find it.
any help is appreciated.
(09-19-2020, 07:18 PM)idillicah Wrote: Hello!
I've not tried these yet because I can't get my fan to respond at all (which GPIO pins did you use?) but they seem well-worth a look.
https://github.com/Matei-Ciobotaru/Tempe...ol-Scripts
https://github.com/Matei-Ciobotaru/Rock64-R64.GPIO
https://github.com/mrfixit2001/Rock64-R64.GPIO
https://github.com/tuxd3v/ats
(06-22-2021, 07:00 AM)Mrfixit2001 Wrote: https://github.com/mrfixit2001/Rock64-R64.GPIO
I use ats to control the case fan in my RockPro64, it works fine. I've also just manually set the fan speed with e.g.
   echo 50 > /sys/devices/platform/pwm-fan/hwmon/hwmon3/pwm1
(You must be root of course)
edit: just realized this thread is about Rock64, not RockPro64...
If you don't want to spend CPU cycles soft-PWMing in userspace, you can use a microcontroller and gpio-fan in the dts to get the same thing done with no userspace daemons or python scripts.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 617 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,193 01-15-2023, 10:36 AM
Last Post: ds00
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,495 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
Smile wooden case for ROCK64 killor 13 16,464 03-04-2022, 06:56 AM
Last Post: killor
  Assembling the premium aluminum case mlefevre 14 15,653 07-07-2021, 05:50 AM
Last Post: Rocklobster
  Configuring Python GPIO Pin Control Rock64 www139 3 7,616 06-22-2021, 06:57 AM
Last Post: Mrfixit2001
  What thermal compound will fit better to the aluminum case? m.bakhterev 1 2,953 01-26-2020, 12:56 PM
Last Post: clach04
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 16,035 07-09-2019, 06:15 AM
Last Post: merwone
  Rock64's temperature while being in aluminium case _zernok 3 5,880 06-23-2019, 08:00 AM
Last Post: rasputin
  low speed wifi pas059 4 5,213 05-13-2019, 12:09 PM
Last Post: pas059
