update programmed crashes
Fresh install, nightly mobian-pinephone-20200915.img, After I set up all of the localizations, I then went to try and update using the software application, as soon as I "updates" tab, the software application crashes .
I know I can update via the terminal, but that may leave the system unstable.
Not sure how how to proceed?
I had this issue before . Try to update it via the console and after this try the program again ... worked for me.
did that, then after a reboot, I received this message with the software package;
unable to download updates:
the following packages have unmet dependancies
<there were no packages listed>
in the terminal I see that gnome-authenticator maybe the culprit
Yep - gnome-authenticator ... I did a update / upgrade this morning and even more issues popped up (python3-yoyo __init__.py could not be deleted ) ... I deleted the file manually and proceeded with the update , not sure if that was the smartest thing to do tho Smile
Let’s hope they fix the repo soon
Same issue. I resolved this via
sudo apt remove gnome-authenticator
followed by
sudo apt install gnome-authenticator
(09-18-2020, 12:24 AM)patrickmollohan Wrote: Same issue. I resolved this via
followed by
nice one Big Grin
worked for me to ....
thank you all.
did the same after reading the replies. As stated above, it worked
again thank you
(09-18-2020, 03:44 AM)jed Wrote:
(09-18-2020, 12:24 AM)patrickmollohan Wrote: sudo apt remove gnome-authenticator
followed by
It's worth noting that apt-get (and by extension, apt) has a reinstall alias:
# man(1) apt-get: reinstall is an alias for install --reinstall
sudo apt reinstall gnome-authenticator
Good tip! However, this didn't work for me either. As with @wasgurd's post above, apt reinstall didn't fix the issue.
EDIT:
Not sure why @"jed" downvoted me over this statement. I said it was a good suggestion, even though it wasn't the right fix. Someone's got their panties in a bunch.
  how to update mobian over tor vusra 13 5,684 07-09-2023, 08:57 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 908 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,033 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 3,131 02-26-2023, 01:01 PM
Last Post: anonymous
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 3,446 11-28-2022, 03:30 PM
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 7,281 10-14-2022, 05:38 PM
Last Post: Krafter
  Wifi issue since last update and held back updates goku499 11 4,227 09-21-2022, 02:39 PM
Last Post: Katsujinken
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,534 09-11-2022, 09:24 PM
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 3,956 09-05-2022, 12:10 AM
  Loving latest Mobian Update drh 11 4,149 08-22-2022, 12:19 PM
