Dormant Projects and Hardware
It is a shame to see the Pine64, Rock64 and PinePro64 no longer being pursued by developers and enthusiasts. Posts to these lists are few and far between. But I understand that passion needs an object of desire and these no longer deliver. Other projects present an appealing challenge.
It would be nice to do more with these great tools. How to reach a wider audience with their potential? We need people who can think outside of the PC world with ideas from left of field, that have been ignored or abandoned by others. The Rasberry Pi has many of these fans. I wish some would come here and take the hardware to new places in science and engineering. My own bias is to see Fedora, and OpenSuse and other mainline distros available to try and reach the wider audience, perhaps with mainline kernel support. But this may not be necessary for some technical projects. What about a competition to find the best new projects for this under-used hardware?
My 2c.
Proud owner of Pine64, Rock64, Pinebook Pro.
I guess there is just too much (often better) competition on the regular SBC market.
I think where Pine64 shines is uncommon stuff that otherwise isn't available or only at much higher prices.
That said: I wish the Sopine modul platform and clusterboard would be developed/expanded further as it is in theory great for home based server clusters.
All things has there own purpose which their strength can be seen Smile
A lot of the effort put into the Pinebook Pro directly affects the rockpro64 and rock64. Same with the PinePhone and Pine64-lts.
Maybe the PineH64 is an exception to the rule (though shouldn't Panfrost bring similar support for the Mali inside of that SBC?).
It will be great if more people were active with the devices, I agree. Better support for the ports would be great, luckily mainline kernel support os close for most of them. A few updated system images will go a long way Smile
Device: Pinebook Pro 128GB No:246 / MainOS: Manjaro ARM
Godot and Flutter - creating something can be fun with the right tools!
(09-07-2020, 02:02 PM)PakoSt Wrote: A lot of the effort put into the Pinebook Pro directly affects the rockpro64 and rock64. Same with the PinePhone and Pine64-lts.
Yes agreed ... the mainline kernel has a lot to offer. My most recent adventure was using the latest Armbian on Pine64+ 2GB. It worked extremely well. I was able to install Docker and Portainer the Docker GUI. My plan is to take a look at Seafile on Docker. Still going.
I would disagree , over the years I've had a few raspberry pi's and a couple of odroids, but currently I'm working on a media server with the rockpro64 NAS setup. I wanted to get away from the other companies slightly and support pine64 . I currently have a pinetab and a rockpro , but eventually I'll hopefully have a pinetime , pinephone pinecil and a few other SBC's like the hardrock64 when it comes out.
I intend to write a tutorial on here when I'm finished setting up my media server, unfortunately I've only been able to tinker the last few weeks , a couple of days at a time.
But to let you guys know what I'm working on its a rockpro 64 running armbian buster with openmediavault as a native install . Running in docker I have jellyfin, Home assistant, Radicale caldav server and nginx as a reverse proxy.
Eventually I intend to run more but this is the current projection . All of it is now working as expected, I'm just working on fail2ban and psad to provide a bit of security .
I must be missing something; can't you load up Armbian on a Pine/Rock SBC and do GPIO projects just like on the Raspberry Pi?
Is there no library or support or... what?
I was going to order a couple Pine/Rock boards and use them on projects that I have planned... whats the holdup?
 pAULIE42o
/s
I think it might just be that the RPi is just so massive it's hard to hear about other SBCs. It's still used and people like it, it's just not mainstream.
  Cryptocurrency payment option and Pine hardware wallet, any thoughts? ohuw67 11 6,073 03-03-2023, 01:18 AM
Last Post: user641
Exclamation More hardware that needs killswitches HulaHoop 0 430 11-17-2022, 06:56 AM
Last Post: HulaHoop
  Does the pinephone have hardware kill switches located on the outside of the phone? unix21311 2 641 10-03-2022, 05:53 AM
Last Post: unix21311
  Pine64 Working on RISC-V Hardware! ImmyChan 0 605 07-04-2022, 02:32 PM
Last Post: ImmyChan
  Pine64 quality of the hardware support : the PinePhone case Gribouille 7 3,066 10-07-2021, 11:26 AM
Last Post: ypd
  Some questions about Pine64 hardware in general RevonCirth 2 2,060 09-17-2021, 08:57 AM
Last Post: gamerminstrel
  Pinenut projects fdlamotte 2 2,247 09-09-2021, 11:32 AM
Last Post: MNtinkerer
  Market Forces and Open Hardware globaltree 10 7,056 06-14-2021, 03:00 AM
Last Post: jannynee
  Hardware related informations guenther 0 1,550 09-10-2020, 04:39 AM
Last Post: guenther
  NAS v2 hardware? mystic221 8 10,593 06-12-2020, 07:13 PM
Last Post: matosys
