"Fancy" screenshot tool not working
Below is a link listed from the Mobian wiki that should take screenshots once the "required packages are installed" my issue is it says notify-send isn't installed but when I use "sudo apt install bash libglib2.0-bin" as per the notify-send GitHub page, it says everything is installed. Has anyone tried this and had success? I'm at work right now or else I would dig a bit deeper.
https://puri.sm/posts/easy-librem-5-app-...creenshot/
Hi there, that woild have been me. Will check the instruction and make the list of dependencies more precise. It had worked on the pinephone when I tried it. Sorry, hut no time today....
(09-02-2020, 12:49 PM)spaetz Wrote: Hi there, that woild have been me. Will check the instruction and make the list of dependencies more precise. It had worked on the pinephone when I tried it. Sorry, hut no time today....
All is well, whenever you figure it out just feel free to let me know!
OK, tried it again and updated the instructions somewhat:
https://wiki.mobian-project.org/doku.php...screenshot
These are the dependencies:
sudo apt install libnotify-bin grim
and this is the screenshot script (I adapted it to store in /home/mobian rather /home/purism
#!/bin/bash
SCREENSHOT=${HOME}/Pictures/$(date +%Y-%m-%d-%H%M%S).png
notify-send -t 1000 screenshot "Taking a screenshot in 5 seconds"
sleep 5
grim "$SCREENSHOT"
notify-send screenshot "Screenshot stored at ${SCREENSHOT}
#!/bin/bash
sleep 5
grim "$SCREENSHOT"
Thank you, mate! I will fix the script today when I get home. I appreciate you getting back to me.
#!/bin/bash
sleep 5
grim "$SCREENSHOT"
Totally unrelated but I figure you know more about this then I do. Do you know where the information is stored when running the command to scale an app?
#!/bin/bash
sleep 5
grim "$SCREENSHOT"
Replied in your dedicated thread
#!/bin/bash
sleep 5
grim "$SCREENSHOT"
I think that this script is only not so useful for the main screen, since that one can only be seen if no apps are running.
In that case you can connect with SSH, and run grim from there.
Except unless you want to show off the background, it might have no meaning to make a screenshot of the main screen anyway.
  Mobile internet via cellular network mostly not working Anna 18 10,117 01-19-2024, 02:59 AM
Last Post: anonymous
Exclamation The internal speaker stops working anonymous 6 969 01-17-2024, 05:53 PM
  APN settings not working with new operator SIM card user641 1 1,013 03-01-2023, 04:43 PM
  Possible Solution for Microphone Not Working Ferriah 0 941 02-13-2023, 01:09 PM
Last Post: Ferriah
  Squeekboard stopped working Zebulon Walton 2 1,161 11-24-2022, 08:41 PM
  suspend inhibit no longer working jsch 3 1,966 10-23-2022, 09:20 AM
Last Post: LibrePhoneUser
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 4,692 09-05-2022, 12:10 AM
  How to get Pinetime working with Pinephone arkadione 12 7,224 08-28-2022, 12:30 PM
Last Post: Fish
  Receiving SMS stopped working treebeard 11 5,467 08-12-2022, 10:31 AM
Last Post: treebeard
  PP keyboard not working at all jojuma 3 1,767 08-03-2022, 10:02 AM
Last Post: jojuma
