Screen has to be on to comunicate with phone
Hi
I installed ssh and samba and they work fine. No problems to communicate with the phone.
However, to be able to connect via ssh or samba, the screen has to be on. If phone is left unattended, screens turn black and communication stops.
is phone sleeping when the screen turns black? I checked in Power settings, and the Black screen can be modified. This should only save energy for the screen but not sleep the phone, or does it?
In my experience this happens when crust kicks in to put the phone to sleep. I believe this is the case because this causes the wifi to cut out which would obviously make ssh lose the connection.
Turn off the default 'sleep after 5 minutes' in the Power settings, or leave the phone plugged into a charger.
good catch!
something to be fixed!
  Screen auto-rotation sensitivity mdk 0 268 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 650 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,188 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 1,230 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,016 01-13-2023, 03:33 AM
Last Post: mdk
  phone does not ring (when sleeping) jsch 2 1,488 10-07-2022, 08:08 AM
Last Post: alaraajavamma
  how to split screen? andrew907 2 1,530 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,809 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,244 07-18-2022, 03:29 AM
Last Post: vusra
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 853 07-17-2022, 10:34 AM
Last Post: 3x5co
