No battery or wifi after poweroff
Hey I tried to find an answer for this for the last few hours but couldn't. I currently can't get any battery info or wifi or even networking on my pinebook pro.
I've booted it off an SD and the internal emmc. The iemmc is running the out the box Manjaro and the SD was running same but with lxqt on a cryptsetup.
A few days back I'd updated the thing and I think there were well over 60 packages and I don't think it was rebooted at the time.
Last night I let the battery run out after forgetting to plug it in and I'm pretty sure it did a poweroff command but anyways when I went to try it out today there's no battery information that can be gotten and nothing is showing up for networking, there's no wlan0. I've also tried a USB wifi and even that won't do a thing and I know it works.
Also the battery certainly works as I can boot it unplugged and run it without ac power with no issues.
Could there been something I screwed up because I didn't reboot it after those updates or what? What can I do here?
Why does this affect both of these? I only updated the os on the SD card.
 Also it's stuck at 6:24 am and no matter how long I leave it on for it always boots up starting from that same time. I've flipped the iemmc switch and just went off the SD and still have the same results. Dmesg indicated a lot of firmware errors and other improper dismount errors on both booted os's.
But how can I fix this?
(07-19-2020, 12:05 PM)Goin2mars Wrote:  Also it's stuck at 6:24 am and no matter how long I leave it on for it always boots up starting from that same time. I've flipped the iemmc switch and just went off the SD and still have the same results. Dmesg indicated a lot of firmware errors and other improper dismount errors on both booted os's.
Having a similar issue where wifi is behaving like it's disabled via physical switches, but led flashes appear to indicate that wifi is enabled.  Usb wifi also doesn't connect.  Did you ever resolve?
prepare a new sdcard with a default os and see what happens?
i would leave charging overnight, then hold power button down for 20 seconds. then boot normally.
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 751 07-13-2023, 01:50 PM
Last Post: PaulQ
  wifi missing some networks filip 0 534 03-11-2023, 03:21 PM
Last Post: filip
  Pinebook Pro drains ny battery after shutting it off Tongman 4 2,023 12-01-2022, 02:50 AM
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 1,834 10-08-2022, 06:22 PM
  Battery Frost1776 1 996 10-07-2022, 04:17 PM
Last Post: LivingLinux
  Pinebook Pro freezes when running on battery petaramesh 5 2,423 09-22-2022, 12:43 AM
Last Post: petaramesh
Heart Now better battery life or power management? KC9UDX 5 2,164 09-09-2022, 08:13 PM
  WiFi Signal Strength? B34N 1 1,125 07-22-2022, 01:35 PM
Last Post: poVoq
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,361 02-22-2022, 11:20 AM
  high battery drain on suspend/poweroff wiz 5 4,921 02-10-2022, 11:52 AM
