NVME problem
I've installed (as described in wiki) Intel SSD 6 660p Series 1024Gb (SSDPEKNW010T8X1). Booted several times. Everything was fine. But next day after booting pbp there is no NVME disk at all (no disk in fdisk and lsblk output). Maybe I can check smth else to debug this problem if disk is not dead? Thanks in advance!
Did you have to fold the ribbon cable from the main board to the adapter, at all? Pinches on the ribbon cable can cause it to disappear.
(07-01-2020, 08:23 AM)tophneal Wrote: Did you have to fold the ribbon cable from the main board to the adapter, at all? Pinches on the ribbon cable can cause it to disappear.
I was able to do this without folding the ribbon. It looks like ok. Just ordered nvme to usb adapter to check if the ssd is broken.
UPD1:
After I secured the ribbon with tape I was able to get nvme work after boot once. But after next reboot it is not available anymore.
UPD2:
Smth wired. The nvme seems to work only after poweroff but not after reboot.
UPD3:
After adding the following line to crontab issue is probably solved (because save switch is not supported).
sudo nvme set-feature /dev/nvme0 -f 2 -v 2
The battery was lower 15% today for the first time after I've installed the ssd.
  New Working nVME gilwood 0 215 02-12-2024, 08:46 AM
Last Post: gilwood
  Problem with USB 3.0 Type A hobbitus 4 1,217 07-15-2023, 11:14 AM
Last Post: dachalife
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,528 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,811 11-28-2022, 12:56 PM
  NVMe drives not detected mattpenn 12 10,380 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,898 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,857 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,726 12-10-2021, 07:47 PM
Last Post: josmo
  NVMe SSD testing methodology halogen 1 2,637 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,790 07-09-2021, 08:45 PM
Last Post: moonwalkers
