Id like to add exfat and hfsplus in as kernel modules.
I noticed there wasnt a build directory /lib/modules/3.10.101-0-pine64-longsleep to compile in kernel modules.
How would I go about doing this?  I have a HFS+ formatted drive I would like to attach for the Plex server and I would rather not reformat the drive and lose compatibility with my iMac.
Thanks in advance,
Cole
(05-15-2016, 12:21 PM)coleshores Wrote: I noticed there wasnt a build directory /lib/modules/3.10.101-0-pine64-longsleep to compile in kernel modules.
Thanks in advance,
Cole
This article will get you to the point of being able to build a Kernel Kernel Compile Guide
Then adjust the guide instruction with the information form martinayotte below.
(05-15-2016, 02:48 PM)martinayotte Wrote: The current default config is arch/arm64/configs/sun50iw1p1smp_linux_defconfig, you will have to copy that into .config at the root.
Then, you can do 'make -j12 ARCH=arm64 CROSS_COMPILE="ccache aarch64-linux-gnu-" menuconfig', navigate into "filesystems" and add "XFS" as a module.
After configured, compile is done with 'make -j12 ARCH=arm64 CROSS_COMPILE="ccache aarch64-linux-gnu-" Image modules'.
exfat is there from memory, not sure about hfsplus...
Let us know if you have any problems.
  PineA64+: Audio in 5.0 Kernel puzzles 6 13,704 11-13-2019, 09:41 AM
Last Post: roel
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,046 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 3,620 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 101,247 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 12,102 06-21-2018, 05:45 PM
Last Post: evilbunny
  Kernel for A64 git longsleep 179 374,910 03-25-2018, 03:25 PM
Last Post: Luke
  Gentoo for pine64 - longsleep kernel incoherent 0 4,808 12-09-2017, 08:14 AM
Last Post: incoherent
  [SOLVED] UEFI + Fedora Mainline Kernel Booting! cztian 0 4,398 07-13-2017, 08:38 PM
Last Post: cztian
  Mainline kernel [Solved] jeroen79 11 25,573 02-08-2017, 06:19 AM
Last Post: umiddelb
Question Need help : Issue in running compiled kernel with tftp+uboot dinesh.bhoyar 2 6,430 01-30-2017, 12:44 AM
Last Post: dinesh.bhoyar
