Mobian screen dims
(06-27-2020, 05:26 AM)a-wai Wrote: Ok thanks! When you have time, could you please read through https://gitlab.com/mobian1/issues/-/issues/3 and replicate the measurements other people did?
(basically, every in_proximity_* files, both with the stock and custom kernel mentioned in the thread)
This would be helpful in trying to understand what's going on here (no hurry, it won't be solved overnight anyway).
Okay will do thanks.
I have exactly the same issue with my BH PinePhone trying to run the latest Mobian.
The login screen works perfectly, but then it turns grey. I can then press the power button a couple of times and use the login screen again, which is correctly drawn on the screen, but then as soon as I unlock, it's a grey screen again.
I obviously haven't been able to setup a WiFi connection yet for it - does the USB connection allow for a SSH connection on a plain Mobian image? I cannot get to a point where I can install anything.
Any help would be greatly appreciated.
Have a look at this thread: https://forum.pine64.org/showthread.php?tid=9694
I replaced my screen recently and forgot to move the "divider" to the new one at first.
After swapping them the issue is gone.
  How to add an homemade app to the main screen? JChdeL 3 301 11-04-2025, 04:13 AM
Last Post: JChdeL
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 41,744 10-27-2025, 10:19 AM
  cryptocurrency on mobian/pinephone biketool 35 57,765 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 26,765 09-15-2025, 02:42 AM
Last Post: georgegohl888
  New Install, apps start but don't show up on screen?! RT3 2 1,798 07-18-2025, 07:56 PM
  XLibre for Mobian Hiraghm 1 2,130 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 273,039 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 1,905 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,438 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,856 05-06-2025, 02:19 AM
